Optimum Shifts
Old May 2, 2006 | 07:52 PM
MattIS's Avatar
MattIS
Default Optimum Shifts
Does anyone know the optimum shift spot on the techometer on the 350 in sports mode? I realize that red line might be optimum but im just not sure about it. Im trying to set my orange circles to go off when to make the perfect shifts. Thanks.
Old May 2, 2006 | 08:11 PM
yellowssm's Avatar
yellowssm
I tried to do this also but the perfect shifts come at different times from every gear change. Gear shift 1-2 I shift at about 1200 before redline. Gear shift 2-3 I shift about 500 before redline. etc. etc.
I wish there was a easy fix to this solution.......like maybe a 6-speed manual transmission (Damn you Lexus!!! in "Stewie from family guy voice")
Old May 2, 2006 | 08:48 PM
joea's Avatar
joea
Is it actually possible to adjust when the orange shift light comes on? (not an owner yet...doing research)
Old May 2, 2006 | 08:52 PM
Phillip31's Avatar
Phillip31
Ya you can change when the orange light comes on for the tach and speedometer
Old May 2, 2006 | 09:01 PM
mwaull's Avatar
mwaull
how do you do this???
Old May 2, 2006 | 09:43 PM
Payam's Avatar
Payam
You use the buttons on the left side of the dash. The one that has the left and right arrows and the on/off button between them. I hope that makes sense to you.
Old May 2, 2006 | 09:51 PM
joea's Avatar
joea
Though not perfect....this is one of the coolest features of this car
One more question...in sport mode will the engine "bounce off" the rev limiter at red line if you don't shift? I heard something about it shifting for you if you hit redline ( which I hope isn't the case in sport mode)
Old May 2, 2006 | 09:57 PM
Payam's Avatar
Payam
As long as the highest gear you selected is the gear your in, it will bounce all day long. For example, if you put sport mode in third gear, and you are going from a dead stop, it will shift first and second gear at redline then bounce off the limiter in third gear.
Old May 2, 2006 | 10:05 PM
joea's Avatar
joea
I see...so if you start if 1st it will bounce off the rev limiter in first until you shift manually to second?
Old May 2, 2006 | 10:10 PM
Payam's Avatar
Payam
Correct.
xiaotian
Dec 19, 2017 09:57 AM
ronfsp
Apr 28, 2013 09:01 AM
x10civ
RX - 3rd Gen (2010-2015)
Mar 6, 2012 06:47 PM
QikSilvr
Feb 26, 2006 06:59 PM
koreanpers
Dec 30, 2003 08:54 AM
