Basslink Subwoofer installed + Pics.
Old Mar 22, 2006 | 07:04 AM
  #31
CaThaFeR's Avatar
CaThaFeR
speshul c
Originally Posted by tim817
Run the power wire on the convenient top located bolt on the positive side of the battery. Then punch the wire through the 4" rubber grommet behind the battery ( i had to remove the battery ). Then run the wire along the passenger door sills, the bottom rear seat.
On the remote wire, I use the red wire at the very end connector on the stock amp locate behind the trunk on the passenger side under the plastic peice at the right corner when you open the door.
This subwoofer has speaker level inputs so I didn't need the RCA converter. Just had to tap 2 of the wire from the speaker level inputs to the stock subs. They are Pink (+) and Sky Blue (-) .I had to remove the rear deck to get access to the stock subwoofer wire.
There's a remote sub level control that i mounted on the pic below.
are these complete instructions? i'm having mine put in this weekend and dont want any mistakes..so i figured i would print this out and bring it with me
Old Mar 22, 2006 | 11:22 AM
  #32
tim817's Avatar
tim817
Oh, i forgot to mention I put a fuse on the power wire coming from the battery before it goes through the firewall? The installer in your shop should know that anyway
Old Apr 10, 2006 | 04:00 AM
  #33
Zoinks's Avatar
Zoinks
Just FYI, Best Buy is selling these things now for $299.
I was going to have them install it as well, but the installer they had was a flaming idiot.
Old Apr 10, 2006 | 06:31 AM
  #34
CaThaFeR's Avatar
CaThaFeR
speshul c
you can get it new on ebay for less than $200 shipped, thats how i bought mine]
Old Apr 10, 2006 | 08:34 AM
  #35
linh811's Avatar
linh811
ditto. They're on ebay all day for $200 shipped.
Old Apr 10, 2006 | 09:06 AM
  #36
trent's Avatar
trent
Good looking install
Old Apr 26, 2006 | 03:52 PM
  #37
linh811's Avatar
linh811
is there much extra space? I'm considering the basslink II and it's about 1" bigger in all dimensions. I would like to mount it in the same position. Thanks
Old Apr 26, 2006 | 04:00 PM
  #38
TurkEclisp's Avatar
TurkEclisp
i put mine in the same spot.. there isnt much extra space. it really is a perfect fit.. i just stick the first ad kit on the side since it has velcro.. it might even slip under it but i think its tight..
Old Apr 26, 2006 | 04:14 PM
  #39
linh811's Avatar
linh811
ah ok thanks
Old May 3, 2006 | 11:44 AM
  #40
linh811's Avatar
linh811
wow what a nightmare. This was my first time and took me nearly 4 hours. Anyway, I t tapped the sub wires from the stock amp connectors, I used the pink and sky blue wires. For the remote I used the small orange wire, again tapped from the stock amp connectors. I haven't installed a fuse yet, can anyone recommend what amperage I might need?
Old May 3, 2006 | 12:24 PM
  #41
RCFormante's Avatar
RCFormante
Supercharged!
Take pics and make a DIY guide
Old May 3, 2006 | 12:33 PM
  #42
jcreech's Avatar
jcreech
If there are any experts on this subject please help!!! No one has addressed how this sub will sound in the car if you have the ML audio. To tell you the truth the ML blows. The bass bottoms out when it is not even turned up half way. I dont wanna spend $$$$ on an all out system in my trunk. Will this basslink suffice? Thanks in advance.
Old May 3, 2006 | 05:15 PM
  #43
linh811's Avatar
linh811
the basslink is better than stock but will definitely not give you a back massage. I think the only way to get REAL bass is traditionally, with amp and box, or some kind of stealth install.
Old May 5, 2006 | 03:03 AM
  #44
RCFormante's Avatar
RCFormante
Supercharged!
Here is a new version of the basslink:
Basslink II:
Anyone tried it yet?
Old May 8, 2006 | 01:11 PM
  #45
flybret's Avatar
flybret
Looks great! Makes me wish I didn't have a golf addiction
