Old Dec 15, 2014, 11:42 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
Illuminated scuff plate, install,problem,solution
Old Jan 30, 2006 | 05:00 PM
  #106
diablo1's Avatar
diablo1
Originally Posted by CaThaFeR
well originally they said it would be $60 when they thought it was a simple thing..but now its going to take probably over an hour to figure out..but they're still only charging $60 because of all the problems i'm having with their tint guy..
OK cool... Hopefully once they do one install, they will know how to do it, and then they won't take so long for subsequent installs...
Old Feb 4, 2006 | 10:01 PM
  #107
CaThaFeR's Avatar
CaThaFeR
speshul c
got mine installed today...they told me they were going to hook it up to the dome light..although i dont think they did because when i turn the dome light off the scuff plates remain on..i think they hooked them to the footwell lighting..i'm going to ask on monday when they are open..i think they shouldve told me this instead of letting me think they were going to be hooked to the dome light..oh and i didnt have it done at my normal shop i had it done at audio designs in hicksville
Old Feb 4, 2006 | 10:20 PM
  #108
STIG's Avatar
STIG
my scuff plates are still in the trunk
Old Feb 7, 2006 | 09:11 AM
  #109
sickntired's Avatar
sickntired
Is it possible to hook into the door and foot well lighting to get this to work like stock? The foot well lighting would provide the power while the door mechanism would provide the "switch"?
Old Feb 7, 2006 | 09:59 AM
  #110
lexus27's Avatar
lexus27
Yes, you should be able to use the door as the switch but only if using the door switch with a relay. The white scuff plate wire should connect to the footwell light. The other blue scuff plate wire needs a positive voltage. The door switch is negative. Use a relay. Depending on the relay you use, you may hear a clicking sound everytime you open and close the door. If they are big, you'll have to hide them. Is it worth it? For me it's not. See my previous post on the operational life of LEDs.
Now, think about this, if you are going to pay a shop to put all that extra relays and for labor because you are concerned that the LEDs will burn out if they are constantly ON when driving, save your money. You can always buy a new scuff plate. Chances are, you won't need to.
Old Feb 7, 2006 | 10:44 AM
  #111
rlonjohnso's Avatar
rlonjohnso
I just installed these this weekend and they look great! Thanks guys (Especially lexus27 and Terp05) for posting the directions and pics. Novice doesn't begin to explain my level of electrical knowledge, but these were a snap to put in. Definitely worth it!
Old Feb 9, 2006 | 06:05 PM
  #112
bagwell's Avatar
bagwell
so you had to hook into the footwell lites as well or were they plug and play?
Old Feb 9, 2006 | 06:12 PM
  #113
tim817's Avatar
tim817
I think those LED will out-last the relay.
Old Feb 11, 2006 | 06:16 PM
  #114
tqlla3k's Avatar
tqlla3k
I think its time to give up, and just do that modification install. Good luck. I really wonder if the connection is near the Overhead console
Old Feb 11, 2006 | 06:28 PM
  #115
bagwell's Avatar
bagwell
I just don't get WHY they wouldn't just be plug and play....ticks me off when they do stuff like this...."here's the plug....oh, but you can't use the plug...hahhaha"
Old Feb 13, 2006 | 06:51 AM
  #116
rlonjohnso's Avatar
rlonjohnso
Unfortunately not plug and play, but the footwell work-around was very simple.
Old Apr 30, 2007 | 12:27 PM
  #117
chaos6458's Avatar
chaos6458
Default re: price
Hello, I'm a newbie. (just got my is yesterday)
Can somebody pm me and let me know how much these plates cost?
Thank you so much in advance.
anthony
Old Apr 30, 2007 | 02:31 PM
  #118
javyLSU's Avatar
javyLSU
2IS OG
Welcome to ClubLexus! You can buy them here. Make sure you use the ClubLexus discount code CL911M for an additional 10% off.
Javier
Old May 1, 2007 | 10:24 AM
  #119
ben_r_'s Avatar
ben_r_
Javier
Yep, should be about $199 shipped.
Old May 3, 2007 | 11:38 PM
  #120
chaos6458's Avatar
chaos6458
thank you so much for the warm welcome guys!
one quick q, is this only for front pairs?
if yes, how much is the cost for rear pairs?
also, this is OEM, right?
thank you.
