Cold idle RPM
Old Dec 12, 2005 | 10:27 AM
gologic's Avatar
gologic
Default Cold idle RPM
Looking for any input from other IS350 owners on cold idle RPM. Mine is in the 1200-1400 RPM range and stays there for at least ten minutes. During this time the temp gauge comes up and settles in around 1/3 of the way. The car tends to lurch a bit because of the higher revs and will drive down the street at 30+ MPH without having to touch the throttle. Just trying to figure out if anyone else is experiencing this.
Old Dec 12, 2005 | 04:14 PM
Payam's Avatar
Payam
Mine does the same thing when it's cold and I first start it up, but once I go into drive, the rpm's come back down to where they should be.
Old Dec 12, 2005 | 04:16 PM
gsrthomas's Avatar
gsrthomas
This is NORMAL.
Old Dec 12, 2005 | 05:07 PM
spwolf's Avatar
spwolf
i think you answered you own question. It lets your car to heat up quicker.
Old Dec 12, 2005 | 05:21 PM
bberisford's Avatar
bberisford
Default Cold Idle
My 250 runs a high idle. Even in gear (drive), the rpm is about 900 to 1000 until the engine is fully warmed up with the temp guage at the stable mid-range position. IWhen fully warm, the idle drops to the normal 600 or so. It takes the engine a lot longer to warm up that my '97 SC or any other car in recent memory.
Old Dec 12, 2005 | 08:07 PM
TheRupp's Avatar
TheRupp
Does it hold the shifts like my ES300 does?
Old Dec 12, 2005 | 10:02 PM
koolaidman's Avatar
koolaidman
its normal. all cars have higher hpms because fuel tends to not mix as well when the car is cold
Old Dec 13, 2005 | 05:31 AM
gologic's Avatar
gologic
Thanks to all that have responded to this. Sounds like it must be normal, but it is a bit higher than any other car that I have had.
Old Dec 13, 2005 | 05:38 AM
jlin101's Avatar
jlin101
it's a bit higher because of gearing (6-sp vs 4 or 5-sp).
Old Dec 13, 2005 | 08:45 AM
umpalumpa's Avatar
umpalumpa
Default I've noticed...
...that my 350 starts up and is @1500 rpm for @10-15 seconds, and then drops down to @1200 rpm. I usually give it the few seconds to drop down until i put it in reverse to back out of my garage. i dont know if i need to do that, but it cant hurt. anyone else notice this?
xCWolf
Sep 2, 2018 08:26 AM
bigblack06
Jul 6, 2016 08:57 AM
JLex23
Nov 26, 2013 03:47 PM
DKKis350
Jan 23, 2011 11:08 AM
749009
Nov 9, 2001 12:35 PM
