Won’t run
Alright guys I’m at a lost I replaced the immobilizer module,car has new plugs, new pcv valve, new fuel pressure sensor and the gas is good but yet I still get no fire up it continuously cranks I spray brake cleaner into the air box( I know how dangerous it is I just had no starter fluid) and it fires up and dies immediately both my cats are hollowed out so it’s not clogged cats but I’m just lost at this point
I’m getting fuel the pump is pumping from what I know unless I’m wrong the procedure was to ground out pins 4 and 13 on the obd2
yes I can hear it I even pulled the hose off after the pump to see if fuel was coming out and fuel was coming out
When was the last time it ran and why was the immobilizer ecu replaced? I'd guess something in that realm is amiss.
IS-350 or 250? I'd guess if Techstream were connected, you'd have a better idea of why its not staying running.
What does the security light do when placed in accessory mode?
Also idk if it would hint or clue something to you but the tpms module also somehow shorted out and my tpms light is on
the security light turns on when in accessory mode and the color on the push start changes from orange to green
and like I had mentioned with some brake cleaner I can get it to fire up but dies immediately as soon as it fires up
I do not have first hand experience to say it is 100% your problem but that security light needs to be off. Im on mobile and hate doing seaches but I doubt the original module was bad. What is more likely is the weak cold start injector in the throttle body kept it from running. Then with repeated cranking the the battery ran low, and data transmission to/from the various computers was compromised and a code was set with the immobilizer placing you where you are now.
I believe that code needs cleared first before trying to start again. That said, do some searching on handshaking the ECU and immobilizer circuit. I think that is the second step and then, apply your starter fluid (brake clean??? -ouch-) and try and start it.
Also search on engine ECU replacement for a 30 minute process that fixes these issues. You might include IS-F forum and yt.
mastaksc400
Aug 3, 2023 05:35 AM
ballew
Apr 9, 2018 10:18 AM
Kanderson1
26
Nov 12, 2012 11:26 AM
