Manually powering a window?
I am pulling an engine from an 2008 is250 and in doing so pulled all the wiring separating the engine from the body. I then realized that the window was not up all of the way. Is there a way to get a battery and "manually" power the switch to close said window?
Thanks
Thanks
Thanks
Thanks
Are you willing to pull the door panel and disconnect the wire harness? Are you ready for that?
gl
I actually already had the door panel off to replace the side mirror (hense needing the window up). But I already simply reattatched all of the wiring harnesses and the battery and then rolled it up. I think that I was over thinking things
Wiring is already re-disconnected now. I think it took me longer to figure out if forcing a window up than simpy reattatching the harnesses
Question, did your alarm go off?
And what happened to the engine?
