IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Remote starter issues
Old Apr 2, 2019 | 04:55 AM
4renerr's Avatar
4renerr
Default Remote starter issues
I have 2012 is250. When engine is cold remote cranks 3x but won’t turn over! Engine warm and it works. Had it reprogram and tact wire checked and problem still exists. Recently replaced battery so I’m thinking not enough charge from battery to start vehicle. Any thoughts?
Old Apr 2, 2019 | 05:46 AM
daddystop's Avatar
daddystop
What check engine lights do you have either on or stored in the ECU?
Old Apr 3, 2019 | 03:37 AM
4renerr's Avatar
4renerr
No engine light and No codes stored
Old Apr 3, 2019 | 04:51 AM
daddystop's Avatar
daddystop
I'd maybe clean your MAF with some approved cleaner for it. Do you have an OBD2 scanner that will let you look at your sensor values as seen by the ECU? This is usually an easy way to diagnose a failure of something like your coolant sensor.
Old Apr 23, 2019 | 07:32 PM
Lexyaaaas's Avatar
Lexyaaaas
Pretty sure that car has an immobilizer? Might have something to do with that if you had to hide a key in there to bypass that. Maybe the hidden key battery died
Old Apr 24, 2019 | 07:11 AM
daddystop's Avatar
daddystop
The key fob doesn't have a battery that controls the immobilizer. It works via RFID which is a "passive" system requiring no power except from the RFID reader that is embedded in your keyswitch/steering column. I don't think this is a "key battery" issue.
Ice1213
Aug 11, 2018 12:05 AM
dskalt
RX - 1st Gen (1999-2003)
Nov 9, 2011 06:39 AM
davisac3
Jan 2, 2011 04:47 PM
a68000
Jul 14, 2008 10:13 PM
LexusRules
Feb 24, 2002 06:36 AM
