IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Gas
Old Mar 30, 2019 | 08:54 PM
lilativan's Avatar
lilativan
Default Gas
Maybe a dumb question but whatever: I have an ‘04 IS300 I was super low on gas, the light was on, so I went to throw $20 in since I had to be to work in fifteen minutes. I told the attendant premium but I looked over and he hit regular instead. Only about a gallon made it’s way in before I looked over and stopped him. He then switched over to premium for the remainder. Is this going to cause a problem? This car has only seen premium its entire life. Am at about 140k miles.
Old Apr 1, 2019 | 10:50 AM
Benoit's Avatar
Benoit
As long as the fuel you putted in wasn't Diesel, everything is allright. A concentration of one gallon of normal in between a good 7 other gallons of premium will not be some kind of problem.
But don't put diesel in this car like my aunt did with her Golf.
Old Apr 2, 2019 | 05:51 AM
daddystop's Avatar
daddystop
Yeah as Benoit said, it should be fine. You just don't want to run a whole tank, your car WILL ping. These engines have 10.5:1 CR pistons in them, they need to use high octane fuels so they don't get preignition.
Old Apr 23, 2019 | 07:54 PM
Lexyaaaas's Avatar
Lexyaaaas
cars these days are really advanced. your car will probably pull timing to deal with the increased knock its getting from the wrong octane. I would just take it easy on the gas pedal until you add premium
Old Apr 24, 2019 | 07:06 AM
daddystop's Avatar
daddystop
Pulling timing to battle knock raises EGT which shortens the life of exhaust valves.... this is NOT a good solution except in the very immediate short term. If you continue to drive a car like this you will shorten the life of the engine, no two ways about it.
Most oem vehicles have no way of monitoring EGT.
Old Apr 24, 2019 | 11:59 AM
Lexyaaaas's Avatar
Lexyaaaas
Good info! thats good to know
patrickkv2
Jun 29, 2015 07:03 AM
ak22801
25
Mar 14, 2011 10:44 PM
SoCal Cyco
Nov 25, 2009 11:00 AM
johnyboiiy
12
Mar 9, 2009 06:29 AM
JohnsRX
RX - 1st Gen (1999-2003)
14
Oct 15, 2004 08:28 PM
