IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Need limp mode help! How do I reset!?
Old Oct 15, 2018 | 06:39 PM
Shrakedown's Avatar
Shrakedown
Default Need limp mode help! How do I reset!?
I have an 04' Lexus IS300 with 3 codes and is currently in "limp mode". I am pretty savy when it comes to mechanics I will do research on my own the codes are:
P0057
P0031
P0420
Any advice or real help would be greatly appreciated. Jokes are awesome as well.
Old Nov 7, 2018 | 10:18 AM
Vanik138's Avatar
Vanik138
Do you currently have any mods in your vehicle right now?
looks like you would need new o2 sensors and cat....
Old Nov 7, 2018 | 02:42 PM
Wh0pp3r's Avatar
Wh0pp3r
P0031Heated Oxygen Sensor (Bank 1 Sensor 1) Heater Control Circuit Low - Manual and Automatic Transmission
P0057Heated Oxygen Sensor (Bank 2 Sensor 2) Heater Control Circuit Low - Manual and Automatic Transmission
P0420Catalyst Efficiency Below Normal (Bank 1) - Manual and Automatic Transmission
Thats pretty much what it sounds like...
simplest way to check the cat is temp gun. simple numbers here, if the inlet temp is say 100, and outlet at 75, the cat is bad. temp exiting should be higher than temp going in.
Old Mar 25, 2019 | 10:57 AM
Shrakedown's Avatar
Shrakedown
Default Problem solved
Not sure how it happened but my cats were clogged with debris (hair *****) 😂 I had a local mechanic rod them out for me. Thanks for your responses and help sorry it took so long for me to jump back on but my 04 IS is quick after now.
Davisito21
May 26, 2019 11:43 AM
Batman09
RX - 1st Gen (1999-2003)
Nov 6, 2018 06:56 AM
sjc12345
Dec 31, 2012 08:12 AM
novak82
Maintenance
Jan 9, 2008 08:45 PM
