IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Engine cut off is200 - need help!
Old Oct 20, 2022 | 12:14 AM
is300mia's Avatar
is300mia
2nd gear
Default Engine cut off is200 - need help!
So i have a 1999 is200. I recently changed the engine from a 1jz to a stock 2J injector. ive been running the car for a week-2 weeks and it was fine, a small misfire but i changed the spark plugs and that fixed it. But recently the car started cutting off as i drive. It was initially in high revs, the rev gauge drops on the dash when it cuts and the engine light turns off. Now its happening alot more in the low revs and seems to only happen when the car is warmed up. Its undrivable. The car jolts hard when it cuts and the car basically dies for a second.
Does anyone have any idea as to what this could be?!!
Old Oct 20, 2022 | 03:27 PM
Arsenii's Avatar
Arsenii
Hello,
A video of the issue will be helpful.
So originally the car came with 3S engine, and then got a swap to 1JZ, which was later replaced again by 2JZ? In such case, a chance of error increases exponentially, and the solution will highly depend on the quality of work done.
Check the Engine Live Data, see what parameters drop when the car starts surging, and go from there. It can at least specify the area to look, whether it's some sensor, wiring or the ECU issue. Other than that, additional information is needed to give any further advice..
Hope this helps and best of luck!
is300mia
Performance
Oct 20, 2022 12:09 AM
EndofDase
Oct 15, 2020 10:08 AM
Sunapollo
Hybrid Technology
Apr 26, 2016 06:29 AM
chris2387
Mar 8, 2015 10:05 AM
indypwr
GS - 1st Gen (1993-1997)
Jul 17, 2003 03:44 PM
