IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
help with wheels
Old Aug 15, 2012 | 02:44 PM
pkjai's Avatar
pkjai
Default help with wheels
i found a set of works cr kawami 18x7.5 offset 47. if i use a 7mm spacer will i be fine?
Old Aug 15, 2012 | 03:45 PM
romycha1's Avatar
romycha1
Yes, you will be fine, but you're probably going to need extended studs.
Old Aug 16, 2012 | 12:23 PM
pkjai's Avatar
pkjai
do you think ill be fine without extended studs? what offset should i like for in 18inche wheels?
Old Aug 16, 2012 | 12:36 PM
romycha1's Avatar
romycha1
I wouldn't chance it.... remember, your wheels are held on by your lugnuts, and if your lugs aren't grabbing enough meat from the threads, just imagine what could happen.
Although... I do know some people using 5mm spacers with no problems, but personally I wouldn't chance it.
Regarding offset, what kind of look are you going for? If you're wanting to be flush, even with a 7mm spacer it won't get you there.
Old Aug 16, 2012 | 01:07 PM
rayy117's Avatar
rayy117
I heard the max size spacers u can get without extended studs is 6mm. I have 5mm just to be on the safe side.
Old Aug 16, 2012 | 07:45 PM
rvalero's Avatar
rvalero
If you're going for a semi-flush look, you'd probably want a 15mm in front, and a 25mm in back. Get something hubcentric like H&R or Ichiba.
Old Aug 19, 2012 | 07:35 AM
pkjai's Avatar
pkjai
thanks i appreciate the help. as for the offset im just lookin for anything that fits without rollin or pullin the fender. the look doesnt have to be aggresive at all.
Old Aug 19, 2012 | 08:05 AM
rvalero's Avatar
rvalero
I think you'd be OK with 215/40/18 tires, 10mm up front, and 15mm in back. Also, those wheels should work fine without any spacers. The front should clear the suspension by a few millimeters, but a 5mm will be all you need if you need anything at all.
SeanO
Apr 4, 2018 03:36 PM
laopadak
Wheels, Tires & Brakes Forum
Nov 26, 2013 12:45 AM
buckwhite
Apr 13, 2012 05:35 AM
ncs98gs
Mar 2, 2009 08:41 PM
SPEED&ECO.
May 13, 2007 12:01 PM
