IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Key won't turn after using wrong key
Old Apr 15, 2012 | 02:10 PM
mansito's Avatar
mansito
Default Key won't turn after using wrong key
My wife tried to start the is300 with the key from our GX470. She realized the mistake, and got the is300 key. Now the key won't turn. I tried to:
  • Lock/unlock the car using the key fob
  • Disconnected the battery and reconnect it after ~5 minutes
But nothing works, the key won't turn. Any recommendations on what to do next?
Old Apr 15, 2012 | 02:54 PM
narfy's Avatar
narfy
take some WD40 and use the straw to spray a bit into the ignition cylinder. do not drench it. just lubricate it a bit. then take the IS300 key and repeatedly try it without using much force. one of the wafers has just jammed and hopefully the lube will free it up...
Old Apr 15, 2012 | 03:38 PM
mansito's Avatar
mansito
I tried that, but it did not work. Then I called Lexus and explained the situation. Lexus said that what my wife did activated the anti-theft system. They asked me to perform the following process to try to reset the anti-theft system:
      Lexus said I need to tow the car to the dealer. That sucks.
      Old Apr 15, 2012 | 04:45 PM
      mansito's Avatar
      mansito
      The root cause was the tumblers were jammed. I gave it a few blast of compressed using my air compressor. Then I used a nail setter and a hammer to tap the key lock. These two steps freed the lock, and I was able to start the car.
      Old Apr 15, 2012 | 09:44 PM
      IS319's Avatar
      IS319
      same thing happen to me, first i sprayed wd40 in the ignition and then taped around the ignition with a flat head screw driver with a hammer, light taps. Like what Mansito said ^^^^^^^ it was jammed and needs to be loosen in order to turn over. I also had the key in it and then turn and hit around the ignition.
      Old May 17, 2012 | 06:43 PM
      rsen99's Avatar
      rsen99
      Same thing JUST happened to me. I don't know where the other Lexus key came from but when I put the correct key in, it would not turn. Compressed air from a can, wd40, and tapping around the keyhole finally worked.
      Old Sep 28, 2013 | 06:15 PM
      ajreinl's Avatar
      ajreinl
      Thumbs up ignition key won't turn after wrong key was insterted
      Thank you! I tried the lock\unlock the doors after trying the compressed air with WD and tapping. Then I went back to the tapping but gave it a couple of good wacks with the end of a rubber coated screw driver and it worked. I wasn't looking forward to having the car towed to a Lexus dealer. I joined Club Lexus just so I could post to this forum and report that it worked.
      My son was being impatient for us to move the car and he grabbed the wrong set of keys. I wasn't real happy thinking his impatience might cost me, I'm guessing around $500.
      Old Dec 11, 2013 | 04:59 PM
      khay425's Avatar
      khay425
      you may need a new cylinder. I know GX and LX ignition cylinders go bad after a while. Its possible the wrong key damaged it beyond repair.
      Old Jul 14, 2016 | 01:51 PM
      watersjle's Avatar
      watersjle
      Default Ignition key would not turn.
      Thanks for all the help. I too accidentally put the ignition key from my 2002 SC430 into the ignition of my 2008 SC430....then when I realized it was the wrong key, I switched to the correct key and it would not turn. tried the lock/unlock 3 times scenario with the door lock and it worked perfectly in the door, but still the key would not work in the ignition. Finally tried a little WD40 and it did the trick.
      Anything CAN be fixed with WD40 or Duct Tape or a combination of the two.
      Old Jul 27, 2016 | 09:40 PM
      woowoo's Avatar
      woowoo
      This may sound kinda dumb
      But have you tried moving the gear selector from P left to right?
      Mines got stuck once but it was because the safety lock was not allowing me to start the car since it wasn't in P but just a little to the right. Hope this helps
      Old Jan 29, 2017 | 09:57 AM
      Mythuan's Avatar
      Mythuan
      It will reset itseft after 30mins or so. I've tried my rx300 key on my wife rx300. It also works when you use wrong key on the doors locks. No worries, be patient and good luck.
      Old Feb 13, 2017 | 11:20 PM
      2jzmn's Avatar
      2jzmn
      Default I got mine to work!
      so all I did was remove all the covers from the ignition and hit the ignition cylinder a couple of times with vice grips and it worked.
      Old Feb 14, 2017 | 02:49 PM
      1985nathan's Avatar
      1985nathan
      I've done this several times having three different lexus models. The simple fix is to us a blunt instrument like a 3/8 extension from a socket set and use it to tap on the top of the ignition switch, only on the metal part. You'll need to use a hammer to make a light tap. You don't have to hit it very hard to free up the lock tumblers. After a few taps check to see if your correct key will work again. Just be careful not to overhit and cause damage to the switch. This has worked every time for me.
      Old Apr 30, 2017 | 03:25 PM
      edwinsc's Avatar
      edwinsc
      Default Sign up to thank you. That worked perfectly After using a 3/8 socket
      Thanks it worked
      reedsrx300
      RX - 1st Gen (1999-2003)
      Nov 2, 2017 02:41 PM
      Wronglane
      GX - 1st Gen (2003-2009)
      Dec 19, 2014 06:15 AM
      MYO4LEXUS
      Aug 25, 2011 08:16 AM
      steevr
      Apr 2, 2011 06:22 PM
      kdb0925
      Nov 25, 2007 01:44 PM
