IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Urgent help needed!
Old Jan 10, 2012 | 03:47 AM
Oakley IS's Avatar
Oakley IS
Default Urgent help needed!
so my 2001 IS 300 Sportcross which has operated 100% no problems for the last 8 years now wont start...and the ironic thing is its supposed to be sold tomorrow!
heres the thing:
my key fob battery and the car battery went out at almost the same time, so I replaced both today.
now I cant unlock the car w the keyfob, I have to do it manually. after I have, I can get the blinkers to show its open or closed.
Inside the cabin light comes on, and the "alarm" light blinks, but theres nothing coming up in the instrument cluster, even when I crank it?
The engine cranks strong, but it wont start. No radio, no instrument cluster, but lights are ok inside and outside..
did I activate a engine demobilizer or something?
please help before I try to sell it tomorrow
thanks!
Old Jan 10, 2012 | 01:50 PM
rayy117's Avatar
rayy117
u might need to do this http://my.is/forums/f221/diy-key-reprogramming-334593/ to reprogram your car with the key
i believe ur car isnt starting because the master key isnt programed to the car. try the spare gray key. the car should start. try it out
Old Jan 10, 2012 | 07:54 PM
rvalero's Avatar
rvalero
I would start by checking all your fuses. Check the driver & passenger kick panels and by the battery. I would start with the MPX-b(?) fuse in the passenger kick panel.
Old Jan 10, 2012 | 11:26 PM
Oakley IS's Avatar
Oakley IS
ok update
so I found none the less than 3 broken fuses.
the main alternator 120A fuse, the tcst fuse and the radio fuse was all blown...
after I replaced al of them, all the electronics seem to work fine, and the instument cluster and radio is back on.
However, the starter crancks, but the engine wont start!
is it possible to mess up the imobiliser when replacing batteries in the fob and in the car at the same time?
this is what it acts:
http://www.youtube.com/watch?v=MaYbcC8yJdo
Old Jan 10, 2012 | 11:59 PM
rayy117's Avatar
rayy117
Try what i posted. My car acted the same when i got a key copied. The car started with the spare key
Old Jan 11, 2012 | 07:03 AM
dsouthmia0's Avatar
dsouthmia0
Yea reprogram the key, Mine did the same thing. When you put the key in the security light on your dash stays flashing right?
brit_lex
Jan 10, 2024 06:32 PM
JulieJ
Jan 19, 2019 06:29 AM
mikedozz
Apr 20, 2014 09:13 AM
russia4lov
Feb 21, 2013 09:20 PM
NjDude
Oct 8, 2007 01:25 PM
