IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Dream Come True.. sorta
Old Dec 1, 2011 | 06:58 PM
210IS300's Avatar
210IS300
Default Dream Come True.. sorta
I have found my dream rims in a actual price I can afford...now i just have to double check the fitment with yal pros out there..
The rims r LM's...
Size - 18x8 (f) / 18x9 (r)
Offset - 42mm (f) / 38mm (r)
Lip Size - 1.5" (f) / 3" (r)
hub bore - 73.1 (I have no idea what that is.. )
Anyways will these fit a stock is300?? Or do I need to do something to fit them? If so what?
ALSO .. any suggestions on tire size for them??( I want it to look clean n flush if possible I can't afford coils til jan)..
Thanks again yal r the BEST!!!
Old Dec 1, 2011 | 07:29 PM
ToMs2jz's Avatar
ToMs2jz
Yes with no prob
Old Dec 1, 2011 | 08:42 PM
210IS300's Avatar
210IS300
Yes! Lol glad too hear.. what about tire sizes??
Old Dec 1, 2011 | 11:25 PM
rvalero's Avatar
rvalero
Roll front and rear fenders. Go with 215 or 225/40/18 and 245/35/18.
Old Dec 2, 2011 | 04:45 AM
210IS300's Avatar
210IS300
Will that size still work once I get coilovers put on?
Old Dec 2, 2011 | 08:02 AM
rvalero's Avatar
rvalero
My wheel specs
F: 18x8 +38 w/ 225/40/18
R: 18x9 +38 w/ 245/35/18
You can do 235/40/18 in back, but that size is pretty tall for our car. It can definitely be done, but I prefer to keep the O.D. close to stock. If you plan to slam it, the shorter tire may be better. Also, when you drop your car, your wheels will naturally camber in. Unless you get a camber correction kit, like Fig's Mega Arms, your wheel will camber in away from the fenders the lower you go. I'm at -1.4 deg now, but it would be close to -3 deg if I didn't have adjustable LCAs.
Old Dec 2, 2011 | 05:48 PM
210IS300's Avatar
210IS300
So rims will fit?
Old Dec 2, 2011 | 08:30 PM
tonynca's Avatar
tonynca
Yes, easily.
Old Dec 3, 2011 | 01:00 PM
SuthrnGent's Avatar
SuthrnGent
Nice wheel choice! and the 73.1 is the hub bore, the lexus hub bore 60.1, so just get a set of hubcentric rings that will close the gap. Then you won't have issues with vibrations.
Old Dec 4, 2011 | 06:21 PM
evan2k's Avatar
evan2k
you will need to fender roll, i have the same set up on 215 slammed, i dont have a camber kit so im going through tires like every 4 months -_-, recommend a camber kit haha
Old Dec 7, 2011 | 03:16 PM
elijah5590's Avatar
elijah5590
they will be awesome
dweezy
Wheels, Tires & Brakes Forum
Feb 23, 2024 10:44 PM
jennypenny
Jul 10, 2014 06:34 PM
Joe C
Nov 1, 2006 09:16 AM
BklynJay
Mar 4, 2006 01:13 PM
