IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Swap Question.
Old Oct 26, 2009 | 04:13 PM
VegasMade's Avatar
VegasMade
Default Swap Question.
Well i recently got out of the honda racing scene and im in the planning of swaping a motor in a is300 5spd.Im still learing about lexus/toyota game.My question was,the Aristo comes with a 2jz gte swap correct? and the supra dose as well.Please correct me if im wrong. So what is the diffrance between these two motors? or is there a diffrance? From what i can see the Aristo is Automatic.I am looking to swap the 2jz gte from the supra into an IS300. But i seen that the Aristo motor is alot cheaper,Why? And what would you recomend for getting more horse power to the ground.Excuse me for sounding like a noob
Thanks in advance guys!
Old Oct 26, 2009 | 08:24 PM
white_is's Avatar
white_is
2jz-gte with vvti is an "easier" swap.
Non-vvti (out of a USDM Supra) requires custom motor mounts.
It's been a while since I've looked into it, so you might want to head over to my.is and do some RESEARCH in the Go Faster section. There are a couple threads that go through the whole process with info and differences between the two.
Advice for putting more power to the ground? Get the v160 with a new rear end. IS 300 5 Speed tranny (w55) is "weak". Some people have broken them with less than 300rwhp. FEW run over 400rwhp.
I highly suggest going to my.is and reading for about 3 months straight. You should be able to find everything you need there. All of these questions have been answered for sure.
Good luck.
Old Oct 27, 2009 | 11:04 AM
VegasMade's Avatar
VegasMade
^^thanks alot man! I'll check out that sight for sure
BHustle84
Performance
May 6, 2019 07:48 AM
GMoney2000
Build Threads
Feb 3, 2018 03:58 PM
ca18det
Mar 23, 2012 09:24 AM
ais300c
Performance
Dec 5, 2011 07:48 AM
cacrawfo
Performance
141
Feb 19, 2007 12:25 PM
