IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Tail Light bulb
Old Feb 15, 2007 | 02:58 AM
infra917's Avatar
infra917
Default Tail Light bulb
im trying to replace the brake light bulb on my 01, how do i get to the bulb?
Old Feb 15, 2007 | 02:49 PM
Dr. Yellow's Avatar
Dr. Yellow
which one? outer ones just remove the 2 screws under the covers. inner - take out the 9 push plugs in the carpet and trunk release handle surround
Old Feb 15, 2007 | 04:29 PM
infra917's Avatar
infra917
ill try it out, thanks!
Old Feb 23, 2007 | 01:32 PM
infra917's Avatar
infra917
well i replaced that bad bulb, and the warning light went off, but only for about a day. its back on now. i've looked at the back lights, they're all on and working fine. anyone know what might be cause the warning light to come on.
Old Feb 23, 2007 | 04:26 PM
Dr. Yellow's Avatar
Dr. Yellow
does it come on after you press the brakes for the first time? could be another brake bulb, just the brake filament. have someone step on the brakes and look at them
Old Feb 23, 2007 | 04:30 PM
infra917's Avatar
infra917
comes on right when i start the car and stays on. i pressed the brake and all my lights are working.
Old Feb 23, 2007 | 04:42 PM
Dr. Yellow's Avatar
Dr. Yellow
it may take a few days and then a filament might blow. same thing happened to me a few years ago.
Old Feb 23, 2007 | 05:56 PM
2OO4IS300's Avatar
2OO4IS300
If you are using replacement LED's they could be the cause...had LED's in my brake lights and the warning light comes on because LED's draw less power than reg. bulbs ...so little power they cause the sensor think the bulb is burnt out...if no LED's not sure the problem sorry
romayayo
Oct 3, 2017 03:58 PM
caverman
Sep 21, 2017 03:21 PM
worldforgo
Apr 2, 2011 06:53 PM
gdave
Feb 22, 2010 08:50 PM
mandyfig
Aug 29, 2007 10:08 AM
