IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Mods!?
Old Feb 11, 2007 | 05:02 PM
MooreIS300's Avatar
MooreIS300
Default Mods!?
Ok I got a 02 IS300, i've tried to do some searches but not too much i have found yet, on a few easy mods that will make the car better..any help will be appricated...any mods will help..thanks
JMoore
Old Feb 11, 2007 | 06:21 PM
Carbon~IS's Avatar
Carbon~IS
What kind of mods are you looking for?
Cosmetic wise, there are tons of body kits, lip kits, and what nots. Performance wise, bunch of bolt on parts. ETC, ETC, ETC...
If you want to do a quick mod, the DRL Mod is free and easy. And the throttle cable spacer mod is cheap and easy.
Try search/looking around is.net, and if you have other alittle more detailed questions, I'll try to help you out
Old Feb 11, 2007 | 09:05 PM
MooreIS300's Avatar
MooreIS300
Okay thanks...whats the DRL Mod?? and what does the throttle cable spacer and the DRL do?? Thanks
Old Feb 12, 2007 | 07:12 PM
Carbon~IS's Avatar
Carbon~IS
DRL = Daytime Running Lights (your highbeams with half the power).
DRL Mod gets rid of the DRL, meaning no more ugly yellow lights when your headlights are not turned on.
TCS Mod get rid of the spring compression on your throttle cable. If you look by your gas pedal, the wire going up to the firewall has a little spring with a plastic bushing attach to it. Just use those large zip ties or a spacer from a RC car shocks, to keep the spring from compressing on the cable.
Old Feb 14, 2007 | 08:51 PM
SDLexus's Avatar
SDLexus
You can also do the easy fog mod (allows you to have the fog lights on independent of the headlights) which is pretty popular. It compliments the DRL mod.
I'd suggest lowering the car and adding sways as a first mod. The stance looks more aggressive after lowering and the car becomes MUCH more fun to drive.
Happy modding!
Old Feb 15, 2007 | 12:26 PM
Faymester's Avatar
Faymester
yea, those 3 mods are on my immediate list ... lights 1st (I think that's probbly easier) then lowering ... I'll post pics after I've done them.
Old Feb 16, 2007 | 08:27 AM
btorok's Avatar
btorok
Painting your calipers and doing drilled & cross slotted rotors isnt too expensive, or hard to do, and really looks good.
Window tint makes a big difference in the look of the car too.
Cat-back exhaust is a bolt on, and around 300-400 bucks depending what you get.
Old Feb 16, 2007 | 01:45 PM
Faymester's Avatar
Faymester
I've got tint, race grill @ spoiler
I think a spoiler of some kind is a deffinate must
Old Feb 16, 2007 | 11:13 PM
Carbon~IS's Avatar
Carbon~IS
eh~ cross drilled rotors tend to crack, but if you want something that will look cool, i guess you can get them....
Old Feb 28, 2007 | 01:34 PM
Ichigo_300's Avatar
Ichigo_300
I like the sound of the DRL, where can i find one??
Old Mar 4, 2007 | 08:38 PM
Slydwyz_IS's Avatar
Slydwyz_IS
http://my.is/forums/forumdisplay.php?f=88
Old Mar 6, 2007 | 12:39 PM
Carbon~IS's Avatar
Carbon~IS
So you want to get DRL for your IS300???
If so it comes standard...
If you want to disable it:
You unplug that thing.
Messy
Mar 24, 2013 12:09 PM
Imperium11
12
Feb 18, 2011 04:15 AM
andyboy
Jul 7, 2008 10:07 PM
