IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
CD Changer issue...Error 3 ??
Old Nov 28, 2006 | 07:10 AM
e_murray's Avatar
e_murray
Default CD Changer issue...Error 3 ??
Hey ,
I got a factory CD Changer in the dash, well this morning i decided to change out some of my discs...
I hit the eject button and it just sat there and flashed at me..
After a minute it's Flashing "Error 3" at me and will not do anything...
I have seen this before and I could just turn the system off and on again and then it would start working with no problem. Well not this time...
Cd player is totally not working...
Help!!
Old Nov 28, 2006 | 12:09 PM
btorok's Avatar
btorok
The Lexus dealer here in Carlsbad told me that happens all the time. It may just be toast unfortunately (sounds like the mechanism is jammed inside). You may have to get a new one, and as far as getting the cd's out of the old one, you may have to take the player apart. I've never done it on this kind. Good luck!
Old Dec 3, 2006 | 12:00 PM
aural's Avatar
aural
mine just did this too... I smacked the side of the console a few times and it works again. I dont know for how long, but it does work.
Old Dec 3, 2006 | 03:57 PM
Faymester's Avatar
Faymester
lol ... what yr r ur guys' is? ... cos ive got a friend whos got an 01 and this happened to him ... ive also got an 01 ... should i be worried?
Old Dec 4, 2006 | 04:35 PM
btorok's Avatar
btorok
My friend at the dealer said its THE most common problem with our stereos.
Old Dec 5, 2006 | 05:58 AM
MSMLexIS's Avatar
MSMLexIS
Try unhooking the battery and the rehooking it back up sometimes this helps.
Old Dec 5, 2006 | 11:53 AM
vboy418's Avatar
vboy418
i had to replace my when it happened. Lucky my car was still under warranty. GL
Old Dec 7, 2006 | 01:36 PM
e_murray's Avatar
e_murray
Default fixed it !
Well, I decided that since it didnt work, this was the oppertune time to tear it apart and see what was inside
Turns out a CD didnt change properly and got stuck.
I then removed the stuck CD and powered it up real quick to see if that helped...
YeaY !!!
Put her back together and been workin Great ever since...
Thanks for everyones input!
Evan
Old Dec 7, 2006 | 03:10 PM
btorok's Avatar
btorok
Very Nice
Old Dec 12, 2006 | 12:18 AM
IS3Hundred's Avatar
IS3Hundred
Don't worry, this is a common problem with our cars.
Old Dec 14, 2006 | 07:50 PM
B.Diddy's Avatar
B.Diddy
Lexotic Concepts
It is rather simple to remove the radio and unjam the CD's yourself if your car is out of warranty. I have unjammed mine a few times. Took me about 30-45min total time. (removal-fix-reinstall)
The jamming is more prone to cars with aftermarket suspensions when you hit a bump in the road precisely when the CD's are shifting from disc to disc.
( i have owned my car for 6yrs and I have documented this )
Old Oct 21, 2008 | 03:24 PM
taze's Avatar
taze
where can i find instructions/pictures on the removal of the stereo?
tcr101
Sep 23, 2009 09:23 PM
xxbillay
Feb 10, 2007 09:12 PM
piscesgirl
Dec 21, 2005 10:54 AM
happypanda
Aug 12, 2005 09:20 AM
JJG2005
Jun 14, 2005 10:01 AM
