Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
Help needed. Cam cover plugs missing
Old Nov 4, 2021 | 05:40 PM
BOV's Avatar
BOV
Default Help needed. Cam cover plugs missing
Can someone help with a pic of their engine bay with cover removed?
looking at a RX450H engine bay and notice there are two plugs on the cam cover are missing, try to trace it back to the loom.
it seems someone replace a different loom as there are few screws aren’t done properly
car had front end repaired
Two plugs missing connectors
Old Nov 5, 2021 | 07:58 AM
Hayk's Avatar
Hayk
What year is this 450h? Here is some pictures I have from previous repair jobs of a 2010 and I can’t find those connectors. Maybe they engine swapped the wrong type of engine? The 450h came with a 2GR-FXE which uses an Atkinson cycle.
Actually I think that’s what happened. They swapped in a regular 2GR-FE which is used on a non hybrid model. The last photo is a picture of my 2010 ES350 with a 2GR-FE. You can see those exact connectors on it.
2010 Lexus ES350 2GR-FE
Old Nov 5, 2021 | 10:54 PM
BOV's Avatar
BOV
my car is 2009.
you might be correct. the wiring on your second last picture is what i have.
this may also explain why one of the wiring case can not be secure to the cam cover...
the cam cover must been swapped, rather than engine as a whole?
Old Nov 6, 2021 | 05:50 PM
Hayk's Avatar
Hayk
Originally Posted by BOV
my car is 2009.
You need the whole engine. It runs on a different combustion cycle so it needs different sensors and may have different internals in the heads. At the very least you would need different engine heads.
2GR-FE: Otto cycle
2GR-FXE: Atkinson cycle
Does this engine run? I’m surprised it was installed with a wiring harness that can’t accept it. Somebody didn’t care or didn’t pay enough to repair it properly.
Old Nov 7, 2021 | 06:46 PM
BOV's Avatar
BOV
I'm actually surprise that the engine is running and drives too! it operate 90% normal, but not as smooth as what a Lexus should be.
i suspect that the cam cover has been damaged and the repairer just use the 2GR-FE valve cover rather than replace the whole head.
i'm looking at ebay and thinking just buy the correct cover and see what happen.
Old Nov 8, 2021 | 09:52 AM
Hayk's Avatar
Hayk
Hopefully that’s all it was but you should really find out what type of engine is in the car.
Old Nov 12, 2021 | 05:46 AM
Clutchless's Avatar
Clutchless
Was this repair covered by insurance? If so you need to file a complaint with your or the offending driver's insurance that the repair was not performed properly because they installed the wrong engine. You may get better results contacting your company first and they will go after the offending driver's company. and thus the repair shop.
Old Dec 7, 2021 | 10:56 PM
BOV's Avatar
BOV
"update"
i have source the 2GR FXE cam cover and fitted.
so previous repairer did a sh^%^&it job may be it was damaged/crack and just use a normal 2GR cam cover.
Car is running smoother and as what a Lexus should.
Thank you for your help
midface
Dec 4, 2015 08:42 PM
Halon
Jun 23, 2014 06:44 PM
t70 supra
SC400 / 300 Classifieds
Dec 13, 2010 08:11 AM
TampRX300
RX - 1st Gen (1999-2003)
Mar 11, 2008 08:29 PM
stocksc3
Maintenance
Nov 17, 2004 11:33 PM
