Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
2013 RX450h performance issues - Hybrid battery
Old Aug 11, 2021 | 10:01 AM
anisinn's Avatar
anisinn
Default 2013 RX450h performance issues - Hybrid battery
I own 2013 450h, recently completed 8 years, doing regular servicing at the Dealership. The performance of my car had deteriorated significantly over last 1-2 years, I have to literally step on gas big time to get my car going when waiting at traffic light, Situation is getting worst every day, when there is small steep road I have to put car in Overdrive mode to keep 40-50 miles per hour speed, complained to Lexus of Fremont few times but did not get any solutions so I would suggest do your homework before buying Hybrid. My car has 86,000 miles on it. Any suggestions, thanks.
Is it battery loses the performance ? Do I need to replace the hybrid battery.
Old Aug 11, 2021 | 10:16 AM
chuckNX's Avatar
chuckNX
Dealer should have completed a battery load test. Did they do any kind of diagnostics?
You may need to find another dealer. I would think the onboard computer has measurements for battery health that a service department can read.
Old Aug 11, 2021 | 11:42 AM
anisinn's Avatar
anisinn
Thanks Chuck for quick response so far Dealer has not done Battery load test. I have Friday's appointment, I will ask them for diagnostics test.
Old Aug 11, 2021 | 11:52 AM
chuckNX's Avatar
chuckNX
Just reading through you first post again. The battery may in fact be fine, and this could be something like an issue with the air/fuel mixture going to the engine.
In either case, I would think the car would be throwing indicator fault lights given the severity of the issue.
Old Aug 12, 2021 | 07:42 PM
ukrkoz's Avatar
ukrkoz
1. air filter
2. general tune up
3. no one "load tests" hybrid batteries. You need BT dongle and something like Dr Prius or Torque to check on battery cells state of charge. Someone here posted before, how to. Use Search feature.
Old Aug 13, 2021 | 07:16 AM
Clutchless's Avatar
Clutchless
FYI there is an independent chain of hybrid shops if you want another opinion: https://www.thehybridshop.com/
Your battery should still be under warranty.
  • Warranty
    • Basic warranty:48 months/50,000miles
    • Corrosion perforation warranty:72 months/ unlimited distance
    • Hybrid electrical components warranty:96 months/100,000miles
    • Maintenance warranty:12 months/10,000miles
    • Powertrain warranty:72 months/70,000miles
    • Roadside assistance coverage:48 months/ unlimited distance
Old Aug 20, 2021 | 06:11 PM
DaRacerz's Avatar
DaRacerz
This sounds like an engine tune-up rather than dying traction battery. Even with a weak traction battery, your performance should be much higher. Have a mechanic take a good look at the computer data, it sounds like a sensor or tune up issue likes plugs, filter, carbon buildup, etc.
Old Aug 22, 2021 | 12:15 AM
Clutchless's Avatar
Clutchless
You need to take it to a different dealer or find a great independent repair shop.
Old Aug 27, 2021 | 05:39 PM
tempestv8's Avatar
tempestv8
Give the Mass Air Flow sensor a squirt of MAF sensor cleaner.
Perhaps you might be in "Eco" mode? Try changing back to Normal mode or try the "Sport" mode.
777rx400h
Hybrid Technology
54
Mar 11, 2025 03:31 PM
eddyv
CT 200h Model (2011-2017)
Oct 28, 2020 09:52 AM
s80heb
Jul 22, 2020 07:41 PM
daddiojigg
Hybrid Technology
Aug 7, 2017 04:22 PM
KevLew
May 1, 2017 08:48 AM
