Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
Recommend Hybrid System Scan Tool
Old Jun 18, 2020 | 07:16 AM
tdott's Avatar
tdott
Default Recommend Hybrid System Scan Tool
Have a check hybrid system light on.
Can anyone recommend a scan tool that can read the code?
Old Jun 18, 2020 | 08:37 AM
Droid13's Avatar
Droid13
I have the ODBLink MX+ unit, probably one of the higher end bluetooth based units, many others are less expensive. I haven't used it to do any serious diagnostic on the RX450h yet thankfully, but I did note that when I plugged it in, the app then told me I could download specific data file to read codes specific for this vehicle. So far I've only briefly reviewed all the possible things I could scan, there is a lot of them. Its also compatible with most 3rd party apps.
I like that you can leave it plugged in (goes to sleep when car is off) and use it all the time for apps that provide real time data while driving without having to plug in and remove each trip. That part seems to work fine. I haven't had a dead battery yet from leaving it plugged in for a few days, and my 12V is now ~11 years old so it probably does not have much juice to spare at this point.
https://www.obdlink.com/mxp/
Old Nov 21, 2020 | 08:17 AM
tdott's Avatar
tdott
I tried Carista and Dr.Prius. Both do not provide detailed INF or sub codes. So I only know it is POAA6 which is a Hybrid system voltage isolation fault. The sub code would tell me where in the system the fault is, but I can't seem to find which code read will be able to reader the sub code other than TechStream.
longlt
Hybrid Technology
109
Apr 8, 2026 12:10 PM
dan88
Hybrid Technology
Feb 15, 2018 04:09 AM
Curated Content Editor
Jan 22, 2018 10:07 AM
devnguyen
CT 200h Model (2011-2017)
Oct 9, 2012 11:02 AM
