Hybrid Technology Unique topics related to the 2016 up RX450h model hybrid drivetrain and other features/options found only on the RX450h. Please use the main forum for discussion about shared components with other fourth generation RX models.
AC Button What does it do!
Old Mar 9, 2017 | 08:41 AM
RLM's Avatar
RLM
Default AC Button What does it do!
I can find no where in the manuals or documentation that tells me what this switch turns On and OFF on the AC control panel.
In my opinion Lexus has very poor documentation for use of the AC system.
What does this switch do and where is it documented.
Old Mar 9, 2017 | 09:12 AM
Htony's Avatar
Htony
Turns AC on meaning you're going into manual mode for climate control for quick heat or cool.
Old Mar 11, 2017 | 10:44 AM
dchar's Avatar
dchar
That switch turns off the rear vents. If no one opens the rear doors before driving, this switch automatically activates.
Old Mar 11, 2017 | 12:40 PM
ggebhardt's Avatar
ggebhardt
Is that the S-Flow switch? Page 288 in the manual.
Old Mar 11, 2017 | 03:25 PM
dchar's Avatar
dchar
Yes. That's the technical name for the switch
Old Jun 12, 2017 | 02:28 PM
TexasRxh's Avatar
TexasRxh
BTW that switch also seems to shut off the passenger-side vents if if there is no one in the seat and the extra cooling is not needed. If a passenger is in the seat those front vents are on. My biggest "challenge" is remembering to turn off the S-Flow switch when people are in the rear seat!
Old Jun 12, 2017 | 04:48 PM
FastFord's Avatar
FastFord
It should come on when there is someone in the back seat. It gets activated by opening the rear door.
Old Jun 13, 2017 | 03:05 PM
ggebhardt's Avatar
ggebhardt
As a double 450h owner, S-Flow has zero advantages for me. I have to over ride it every time I get in the vehicle.
i will ask Lexus if they can override it to stay OFF. When I get in a hot car, I want BOTH center vents pushing cold air.
Old Jun 17, 2017 | 09:02 PM
lexnewbi's Avatar
lexnewbi
I normally put my briefcase behind the drivers seat, then I climb in. Whenever I have checked the rear vent after driving for a while, the rear vent is not blowing any air. I would expect that on days with temperatures above 85F, all vents would be working to cool the car.
I looked on Carista to turn Sflow off, but it had no setting.
Old Jun 18, 2017 | 04:52 AM
FastFord's Avatar
FastFord
I suspect that it is not on because you put the briefcase in before starting the car. I don't know if that's how it works or not. I know that if I pick someone up and they get in the back the air is moving. You can always just hit the s flow button. I find the whole system a little different. I don't like the sflow that much and would prefer it just blows air everywhere all the time. It would be nice to have an on/off button for the air.
Old Jun 18, 2017 | 01:40 PM
lexnewbi's Avatar
lexnewbi
Today, the kids got on the back, then I got in. The rear vent had no air and the kids complained it was hot. I had to turn off the s-flow and then the rear vent started blowing air.
I am not sure how S-flow detects passengers. The manual states that of a rear door is opened and closed, the S-flow turns off. However, that is not my experience. Maybe the rear door must be opened after the front door.
Old Jul 15, 2017 | 05:49 AM
ggebhardt's Avatar
ggebhardt
I think Lexus might be changing this in the future and allowing the driver to have the vehicle default to always on. Reason I said so is that I am participating in a Lexus driver survey I get every week. In the second survey there was extensive questions about how often people sit in the back seat and how often you over rode the s-flow button.
I want my S-Flow off all the time. My 450h saves no fuel by using it and when the vehicle is really warm the extra vents are desired to cool the vehicle quickly. They just need to have the S-Flow button to remain at the last driver setting.
Old Jul 15, 2017 | 06:16 AM
LordBowral's Avatar
LordBowral
I agree ! It's absolutely infuriating and saves nothing
Old Jul 17, 2017 | 11:05 AM
ericsan13's Avatar
ericsan13
Strange, I can turn off my s-flow and it stays off.
Old Jul 17, 2017 | 12:01 PM
ggebhardt's Avatar
ggebhardt
If I open one of my back doors to toss something in the back seat and then get in the car it always turns off S-Flow and illuminates the rear seat belt light on the dash.
