Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Phone Book
Old Jan 3, 2008 | 07:24 AM
Briankim79's Avatar
Briankim79
Default Phone Book
I was wondering how you upload a phonebook into the bluetooth of a 2006 RX
Old Jan 3, 2008 | 09:50 AM
SLegacy99's Avatar
SLegacy99
You have to enter it in manually. Its annoying.
Old Jan 4, 2008 | 02:04 PM
williz's Avatar
williz
this depends on your cellphone. not all cell phones are able to upload the whole phone book at once. on most cell phones you have to transfer one entry after the other.
i enclose two examples of a procedure here:
Nokia N70 this one support the upload off all telephone book entry's at once!
Nokia N70
Pairing
• Ensure the HF is in pairing mode.
• Press the Menu key on the AG and scroll the Connect folder.
• Open the folder and select Bluetooth.
• Make sure Bluetooth is switched on.
• Using the directional keys scroll right to the Paired Devices screen.
• Press Options and select New Paired Device.
• Once the AG has located the HF select it from the list and enter the Passkey displayed on the HF
screen, when the AG gives you the option to authorise the HF select Yes.
• Select options then connect.
• The HF and AG are ready for use.
Sending contacts one-by-one to the Handsfree System.
• Select PHONE BOOK TRANSFER MODE on Hands free system
• Select CONTACTS.
• Select SEARCH, select the contact, and then OPTIONS.
• Select SEND, select VIA BLUETOOTH (waiting...).
• Select “Hands free system”, press SELECT (waiting...).
• The contact is now added to the phone book.
Sending your whole phonebook to the Handsfree system
• Select PHONE BOOK TRANSFER MODE on Handsfree system
• Select CONTACTS.
• Select OPTIONS, select MARK/ UNMARK, and select MARK ALL.
• Select OPTIONS, select SEND, select VIA BLUETOOTH (waiting...).
• Select Hands free system, press SELECT (waiting...).
• All the contacts are now added to the phone book.
Motorola V3i with this one you have to upload telephone book entry's one by one
Motorola V3i
Pairing
• Enter the menu of the handset and scroll to connectivity and press select.
• Scroll right to Bluetooth and open.
• Once the Bluetooth folder is open Handsfree will be highlighted, press select and then select look
for devices to begin searching.
• Select HANDSFREE from the found devices list and enter the passkey displayed on the HF screen.
• To check the device is authorised.
• Still in the Bluetooth menu scroll down to Device History, highlight HANDSFREE and press the
centre key. This will allow you to change the device name and/or set it as authorized.
• Click on the main menu button of handset and enter the PHONE BOOK.
• Select the contact you want to send over Bluetooth and press the main menu button.
• Select SEND, select BLUETOOTH and [LOOK FOR DEVICES] (waiting...).
• Select Handsfree System, press SELECT (waiting...).
Old Jan 4, 2008 | 10:55 PM
Briankim79's Avatar
Briankim79
I have a Blackberry 8830. So is this possible?
Old Jan 5, 2008 | 01:35 AM
williz's Avatar
williz
lexus.com lists the blackberry 8830 as compatible and and phone book transfer at onces as supported. have a look here. on the left side below the blackberry picture you will find the quick guide pairing instructions for your phone!
http://lexusbluetooth.letstalk.com/b...4&passedPaIds=
BLUETOOTH FUNCTIONS COMPATIBLE
with 2006 Lexus RX 400h
Handset will pair to vehicle Yes
Handset will place a call through the handsfree system Yes
Transfer single number phonebook entries to the handsfree system No
Transfer multiple phonebook entries to the handsfree system at once Yes
Handset reconnects automatically when the vehicle is started Yes
Switch from handsfree mode to private mode using the phone's keypad or menu Yes
Switch from private mode to handsfree mode using the phone's keypad or menu Yes
Phone's auto answer function works properly when connected to the handsfree system No
Handsfree system displays incoming caller identification Yes
Handsfree system displays the cellular network signal strength Yes
Handsfree system displays the roaming status from the cellular network No
Handsfree system displays the battery level of the phone No
Ringing heard through the vehicle's audio system when receiving incoming handsfree calls No
Calls placed from the phone's keypad are placed in handsfree mode Yes
Accept an incoming call using the vehicle's off-hook steering wheel switch Yes
Accept an incoming call through the Handsfree system using the phone's 'Send' button Yes
Reject an incoming call by pressing the vehicle's on-hook steering wheel switch Yes
Reject an incoming call by pressing the phone's 'End' button Yes
Dial a number 24 digits long using the handsfree system Yes
Dial an international number using the '+' prefix Yes
Dial in international number using the '011' prefix Yes
Terminate a handsfree call using the vehicle's on-hook steering wheel switch Yes
Terminate a handsfree call using the phone's 'End' button Yes
Cancel an outgoing handsfree call before the other party answers using the vehicles steering wheel on-hook switch Yes
Cancel an outgoing handsfree call before the other party answers using the phone's 'End' button Yes
Cancel an outgoing call from the handset before the other party answers using the vehicles steering wheel on-hook switch Yes
Cancel an outgoing call from the handset before the other party answers using the phone's 'End' button Yes
Transmit DTMF tones using the handsfree system's digit entry with the tones heard through the vehicles audio system Yes
Transmit DTMF tones using a stored number from the handsfree system's phonebook with the tones heard through the vehicles audio system Yes
Transmit DTMF tones using the phones keypad with the tones heard through the vehicles audio system Yes
Transfer single number phonebook entries that contain special characters to the system (p, w, etc.) No
Switch from handsfree mode to private mode using the handsfree system 'Transfer' button No
Audio system returns to its previous state automatically if the other party hangs up the call prior to pressing the 'On Hook' or 'End' button Yes
Switch from private mode to handsfree mode using the handsfree system 'Transfer' function No
Powered by LetsTalk.com
Old Jan 5, 2008 | 07:36 AM
Briankim79's Avatar
Briankim79
i am sorry, but I was just wondering where the instructions are to upload the phone book? I have it connected together, just need to upload the phonebook.
thanks
Old Jan 5, 2008 | 02:51 PM
jduboc's Avatar
jduboc
Default 400h bluetooth
Can you pair two bluetooth cell phones to the car at once? Seems to only let me have one connected at a time but has two separate phone books. any ideas?
Old Jan 16, 2008 | 02:58 PM
LxsTekGuy's Avatar
LxsTekGuy
briankim... go to the lexus.letstalk.com website and find your phone... then click on it and select "quick guide pairing instructions" on the left side of the screen.
Old Jan 16, 2008 | 03:00 PM
LxsTekGuy's Avatar
LxsTekGuy
jduboc, the system will let you pair two phones, but only allows you to use one at a time. You select which phone from the settings menu. You can either use one phonebook for both phones, or you can manually switch phonebooks when you switch phones, but it won't automatically switch phonebooks or phones for you.
RLM
RX - 3rd Gen (2010-2015)
Mar 9, 2016 09:35 AM
jgoergen
Apr 24, 2007 11:22 AM
newgx
GX - 1st Gen (2003-2009)
Feb 7, 2006 10:56 AM
mlustgarte
May 30, 2005 10:38 PM
