Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
12v Power Outlets? No Power
Old Dec 16, 2007 | 09:37 AM
nardopolo's Avatar
nardopolo
Default 12v Power Outlets? No Power
So i have just recently bought myself a new 400h and enjoy it greatly. My question though is, how do you turn on the power to these 3 12v outlets? The manual says there is a button next to the fuel tank and the afs (or aps) off button, but there is an empty button there that cant be pressed. What can i do?
Old Dec 16, 2007 | 11:17 AM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Do you have the Rear Seat Entertainment System on your RX? If you do, there is a cut off switch on the dash next to the AFS button for the a/c outlet in the back. The a/c plug is located next to the A/V inputs so you can plug in any electronic video/audio accessory to view with the rear drop down lcd. If you don't have RSES, you will have a blank button in that area you just mentioned.
Old Dec 16, 2007 | 12:01 PM
nardopolo's Avatar
nardopolo
i don't have rear seat entertainment, but that means none of the 12v outlets will work? if they do, how do u turn it on
Old Dec 16, 2007 | 01:22 PM
flipside909
Lexus Connoisseur
25 Year Member
If you don't have RSES, you don't have the 115 cut off switch on the dash. There is a DC plug in which is next to one of the area lamps underneath the cargo cover rail. There is no way to disable it unless you physically unplug it from behind the trim or pull the fuse.
Old Dec 16, 2007 | 02:00 PM
Bear60's Avatar
Bear60
You turn on the 12 volt plugs by turning on the ignition.
Insureit1
LX - 3rd Gen (2008-2021)
Aug 20, 2013 11:00 AM
acheparev
HS 250h Model (2010-2012)
Oct 21, 2010 01:16 PM
IS_NIICE
Feb 8, 2007 05:54 AM
rshngrhino
May 31, 2006 12:46 AM
ted920
Jul 25, 2005 01:32 PM
