Hybrid Technology Unique topics related to the 2023 up RX model hybrid drivetrain and other features/options found only on the hybrid models. Please use the main forum for discussion about shared components with other fifth generation RX models.
Hybrid malfunction
Old Jul 10, 2023 | 06:10 PM
  #31
Steveg67's Avatar
Steveg67
Originally Posted by Ryebrid
My dash cleared itself of all errors. It's been good for the past 200 miles. If I bring it in as scheduled, will the dealer find the codes in history?
i wouldnt let the dealer touch the car unless u want to be without it for months
Old Jul 10, 2023 | 06:34 PM
  #32
Ryebrid's Avatar
Ryebrid
Well, it is the first model year of a major overhaul, so I'm not shocked. I'll ask the dealer what they suggest.
Old Jul 21, 2023 | 05:20 AM
  #33
Ryebrid's Avatar
Ryebrid
All fixed! My problem turned out to be a defective turbo valve, which was repaired in 1 day. Dealer support was excellent and I'm relieved they were able to pin this problem down. Gas mileage went up and my starts are smoother now, also.
Old Jul 21, 2023 | 06:13 PM
  #34
Urlik's Avatar
Urlik
Wastegate?
Old Jul 22, 2023 | 04:05 AM
  #35
Ryebrid's Avatar
Ryebrid
Originally Posted by Urlik
Wastegate?
Yes, I'm not sure what that does exactly.
Old Jul 22, 2023 | 04:31 AM
  #36
Urlik's Avatar
Urlik
From wiki: A wastegate is a valve that controls the flow of exhaust gases to the turbine wheel in a turbocharged engine system. The diversion of exhaust gases regulates the turbine speed, which in turn regulates the rotating speed of the compressor. The primary function of the wastegate is to regulate the maximum boost pressure in turbocharger systems, to protect the engine and the turbocharger.
Old Jul 22, 2023 | 09:58 AM
  #37
Carbuff2's Avatar
Carbuff2
Just to build on what @Urlik said:
If a wastegate sticks OPEN, the turbocharger can not spool up and provide the desired power.
If it sticks CLOSED, too much pressure (PSI) will be applied to the combustion chambers...and that could damage the engine.
I was recently playing with the instrument displays, and there is a boost gauge available there on the 500h, which would help determine what the specific issue is
Old Jul 22, 2023 | 10:12 AM
  #38
Ryebrid's Avatar
Ryebrid
Ah; glad I took it in then and didn't wait for it to get worse! The problem was intermittent.
Old Jul 22, 2023 | 12:12 PM
  #39
Steveg67's Avatar
Steveg67
Turns out there was a damaged seal in the valvebody that was restricting flow and causing malfunction
the seal we need is in japan with no eta
Old Jul 22, 2023 | 01:24 PM
  #40
Bradleys13's Avatar
Bradleys13
2nd gear
Thumbs down Hybrid malfunction on 23 500H
I took my new 500H on one road trip and it failed at 4,000 with Hybrid System Failure. It's been in the shop waiting on a transmission control module (TCM) for 8 weeks. The new part came in this week, damaged, and they have to order another one. They have no idea when another part will arrive and it might not be the root cause of the issue, I'm told. It's been sitting in the hot Texas sun for 8 weeks (normally garaged) and that can't be good on the interior. I went from BMW to this car, thinking it would be a reliable car. Not the case. I don't have the car I paid for and I wish I had never bought it!
Old Jul 22, 2023 | 05:38 PM
  #41
Ryebrid's Avatar
Ryebrid
Oh, that's annoying. I can't believe we're still dealing with parts shortages. Rack up the free miles on the loaner car.
Old Aug 3, 2023 | 11:35 AM
  #42
Steveg67's Avatar
Steveg67
Visited the dealer yesterday to retrive my belongings after they said part eta is now 8/17 citing the part (transmission seal) has not been manufactured yet
so today i started a lemon law lawsuit with a group that specializes in this matter.
in NY you can start the lemon law if one of the two or even both of these situations occur
1. vehicle has been to the dealer 3 or more times for the same problem.
2. Vehicle is at dealer for repairs for more than 30 days
i fall into the 30 day category. It has been close to 90 days
lawyer said i will either be heavily compensated or i will get a brand new replacement.
i would rather get my money back so i can go back to my silverado jmho
Old Aug 3, 2023 | 11:43 AM
  #43
Ryebrid's Avatar
Ryebrid
I would think the most comparable vehicle would be the X5, but that's also just been redesigned and could have teething issues also.
Old Aug 3, 2023 | 12:21 PM
  #44
lexusnyca's Avatar
lexusnyca
Ask for a buyback, they can resell this car after they repair it (on their time, not yours) so it should mean nothing to them. Then you can either get into a new one or just walk away, maybe get on the list for the new Land Cruiser if you want something more rugged.
Old Aug 10, 2023 | 12:01 AM
  #45
Steveg67's Avatar
Steveg67
Parts have finally arrived hopefully back in the next day or two
