HS 250h Model (2010-2012)
Manifold Dichotomy...
Old Jun 11, 2016 | 07:33 PM
MSAGRO's Avatar
MSAGRO
Default Manifold Dichotomy...
New owner of an HS Premium. Very Happy.
Question: The manifold on almost all of the HS models looks like a rusty manifold off a barn find 1938 Hupmobile.
Will high temp paint work? Has anyone done this? (Photos Please)
Also, the deck behind the rear seats are a matching light grey matching the seats. The reflection against the back window cuts the view in half. Again, any solutions regarding this?
Old Jun 11, 2016 | 08:34 PM
TheAirman's Avatar
TheAirman
I agree with you. Under the hood, you have a real nice engine cover, but what take up most of the real estate is that rusty manifold right there front and center.
If you knew how much that thing costs, you'll use maximum caution as you try to beautify it.
But if you try, maybe the Rustoleum 2000 deg. F flat black might work. Post pictures.
Also for the rear view out the window, I took out my headrests. If I need to carry someone in the back seat, I just put the headrest back in. It helps with the view out backwards, and that reflection.
Old Jun 11, 2016 | 10:08 PM
MSAGRO's Avatar
MSAGRO
Airman thanks for the fast response. I will try that rust oleum and post pics.
The back seat head rests aren't the problem. It's the light grey rear deck fabric reflecting against back window, the glare of the fabric makes the view out the rear almost opaque. Seems like a bad design.
Old Jun 20, 2016 | 08:31 PM
MSAGRO's Avatar
MSAGRO
Airman, thanks for the tip. Used the 2000 degree Rustoleum. Primer base, then flat black. Big improvement.
Old Jun 21, 2016 | 04:13 AM
corradoMR2's Avatar
corradoMR2
The pursuit of F
^^^ Big improvement! Did you sand it down first to remove any superficial rust?
Old Jun 21, 2016 | 07:10 PM
TheAirman's Avatar
TheAirman
Oh my. That is lovely !!!!
Darn. Another project on my list, because now I have to copy your job !!!
Old Jun 21, 2016 | 07:19 PM
TheAirman's Avatar
TheAirman
Oh, and just so you know, now that you're done touching it, that part is very expensive:
http://www.lexuspartsnow.com/parts/l...051-28320.html
Old Jun 22, 2016 | 06:49 PM
corradoMR2's Avatar
corradoMR2
The pursuit of F
over a grand!
Fo once, it's cheaper here in Canada. Covert to USD, and this is a reasonable $500
http://www.lexuspartsdirect.ca/produ...rm=25051-28320
Old Jun 23, 2016 | 09:31 AM
MSAGRO's Avatar
MSAGRO
Yes Corrado, did prep by putting solvent on ScotchBrite pad, then steel wool until smooth. Then I took a rag with isopropyl alcohol to remove oils and remaining particles. Masked, then followed directions on primer and paint. After a week. Still looks good.
Old Jun 23, 2016 | 09:36 AM
MSAGRO's Avatar
MSAGRO
Corrado, I also owned an MR2...this was mine.
Old Jun 23, 2016 | 02:20 PM
corradoMR2's Avatar
corradoMR2
The pursuit of F
Brings back memories
I had a white one too. A '91. Here's a pic of a pic from over ten years ago (remember back then, we actually printed photos! )
BTW, going back on topic, thanks for the prep picture/post above.
nuck
Apr 5, 2016 07:46 AM
noku
Apr 22, 2011 03:11 PM
Rustito
Feb 21, 2008 10:09 AM
rybikowsky
Dec 3, 2003 01:48 PM
chatrathi
RX - 1st Gen (1999-2003)
Apr 7, 2002 07:28 PM
