HS 250h Model (2010-2012)
headlights out
Old Nov 4, 2023 | 01:36 PM
yoyo2's Avatar
yoyo2
Default headlights out
So my trustworthy HS250 had one headlight out two days ago and last night I noticed the second one also went out. I drive the car only 3 times a week each time about 20 miles. Before I get it to the dealer I wonder if anyone have any idea what might have gone wrong? My guess is the lightbulbs. High beams and daylight running lights are good. The other thing I noticed that the light switch on the steering wheel seemed out as well. I remember if I switch between auto/head/high bean the switch itself highlited.
Thanks.
Old Nov 4, 2023 | 03:23 PM
850R's Avatar
850R
Yup, your bulbs have failed. Get a pair of H11 bulbs and install them. Here is a video to help you:
Old Nov 4, 2023 | 05:11 PM
yoyo2's Avatar
yoyo2
cool. thanks for the confirmation. seemed like something I can do to save a couple of bucks!
Old Nov 4, 2023 | 05:38 PM
850R's Avatar
850R
Install a set a Zevo LED bulbs that are shown in the video. They are pricy, about $100 USD per pair, but once you install them, they will last the lifetime of your car.
Old Nov 4, 2023 | 06:31 PM
yoyo2's Avatar
yoyo2
I ordered these from advancedautoparts: https://www.sylvania-automotive.com/...H11SU.BP2.html
but I just realized they gave me those https://www.sylvania-automotive.com/...11BSU.BP2.html
doesn't look like they will fit, right?
I did a search for Zevo LED but didn't find anything that looked like the original that can fit into my HS250HS, do you have a link? Anyone else using LED that will replace the original without adding some adaptors?
Thanks
Old Nov 4, 2023 | 08:00 PM
850R's Avatar
850R
Thanks
Those will work. It is important to use the H11, the brand doesn't matter. As for for the LED Zevo, here is a link where you can buy them:
Zevo LED Zevo LED
Old Nov 5, 2023 | 04:55 AM
Clutchless's Avatar
Clutchless
Those Sylvania H11B bulbs will not work as the connections are different. H11 has recessed plug connections, and that is what you want. H11B has protruding connections that will not work in the HS250h. https://sealight-led.com/blog/h11-vs...ifference.html
You will probably have to return them. H11 bulbs are very common, used by many car manufacturers and every auto parts store has them in stock.
Do not touch the glass with bare skin as the oils make for a hot spot on the bulb and a shorter life. If touched, clean it with alcohol. I wear thin disposable gloves when changing car light bulbs. The hardest part is removing all those clips on the engine cover!
Old Nov 5, 2023 | 09:17 AM
yoyo2's Avatar
yoyo2
you are absolutely right. I took the burned bulb out and noticed immediately the H11B has a different connector. Now I need to return these and tell them to give me the correct one. What a pain.
Old Nov 5, 2023 | 05:53 PM
yoyo2's Avatar
yoyo2
Done. worked like a charm. Total cost $48 and two trips to advance auto parts.
Thanks everyone!
Old Nov 5, 2023 | 05:58 PM
yoyo2's Avatar
yoyo2
Are these supposed to have backlighting?
siemka321
Oct 9, 2023 06:35 PM
Mahrez
GS F (2016-present)
Jun 13, 2022 09:05 PM
jeremy93ls
Mar 30, 2020 11:41 AM
jottinger
GS - 1st Gen (1993-1997)
Jan 23, 2017 08:52 AM
sderman
12
Jun 4, 2014 07:23 AM
