2012 lug nut replacement
Old Dec 17, 2022 | 07:03 AM
Wmb67's Avatar
Wmb67
9th Gear
Default 2012 lug nut replacement
Has anyone replaced their oem lug nuts with aftermarket nuts? I took the wife's wheels off for a thorough cleaning and rotation before winter and noticed that a few nuts were tight in my wrench along with a few are starting to rust. It seemed similar to my Tacoma, which experienced swollen lug nuts that I replaced with Gorilla solid lug nuts. I was curious if any GX460 owners had experienced the same swelling and if there were any recommendations.
Old Dec 17, 2022 | 07:39 AM
IanG's Avatar
IanG
It may be your socket rather than the lug nuts "swelling" You should use a 21 mm socket, many use a 13/16" but that is only 20.64mm which is 0.36mm smaller ... a very tight fit. Use a 21mm not a 13/16".
Old Dec 17, 2022 | 11:16 AM
JZZFZZ's Avatar
JZZFZZ
Yes. Many time. The after market ones get rusted quicker but I have not noticed anything else.
I started to use 6 point socket as opposed to 12 point ones and started to see slower corrosion. Impact socket is even better.
Jerry0249
May 13, 2022 02:40 PM
ScBouncE
Jan 27, 2014 06:58 AM
solow97
IS - 1st Gen (2001-2005)
Nov 7, 2012 05:57 AM
telmz1
Aug 10, 2011 08:50 PM
Gernby
Oct 19, 2007 12:39 PM
