HELP - Lost diamond earring
Old Jul 2, 2020 | 10:30 PM
DADLER's Avatar
DADLER
Angry HELP - Lost diamond earring
I own a 2018 GX460. So my wife got into the car and when she took off her mask, her diamond earring went flying off and it is nowhere to be found in the vehicle. She thinks it flew into the backseat. Newton's Second law would suggest that it went flying forward (also her ear would have prevented the earring from flying backwards). I think it may have fallen into the defrost grill or behind the drivers' panel (by the airbag). Ideally, I would like to remove the top defrost grill and the lower panel underneath the steering wheel and get a good look inside those areas. I have already tried a boroscope to no avail.
I'd like to give it the college try before I waver and shell out another few thousand dollars to replace the earring. Does anyone have a diagram or a procedure to assist in this endeavor? I'm pretty handy (used to do all the mechanical work on my 85 Corvette) but these new cars (with airbags and computers everywhere) look very intimidating.
Thanks in advance.
Old Jul 3, 2020 | 05:58 PM
ASE's Avatar
ASE
Thanks in advance.
Given you have no idea as to the trajectory ... taking things apart does not make sense. It would have taken arcing path, and then potentially dropped via gravity into a ventilation duct or other place behind the dash. So your BoroScope approach makes sense assuming it is small, flexible with sufficient length to explore all potential places it could have dropped into.
Old Jul 3, 2020 | 08:09 PM
DADLER's Avatar
DADLER
Thank you for your reply. If it made it into the defrost grill, where would it have come to rest? Stated somewhat differently, do you know where the defrost grill originates from?
Old Jul 3, 2020 | 09:34 PM
ASE's Avatar
ASE
Schematics ? ... Anyone ? .... Anyone ?
Old Jul 4, 2020 | 05:21 AM
Acrad's Avatar
Acrad
There are some rough schematics here
https://www.clublexus.com/forums/gx-...eshooting.html
I've attached dashboard removal instructions as well.
File Type: pdf
Old Jul 6, 2020 | 09:44 AM
ASE's Avatar
ASE
Before assuming the worst ... that it fell into the bowels of the dashboard ... check in-between the seat and the center console, specifically in the seat track.
Old Jul 6, 2020 | 11:46 AM
DADLER's Avatar
DADLER
Thanks we looked in the tracks with the Borescope. Not there.
Old Jul 7, 2020 | 07:34 AM
Craigyyy's Avatar
Craigyyy
File insurance claim.
Old Jul 9, 2020 | 02:58 PM
nuclearn8's Avatar
nuclearn8
If they were real diamond earrings I'm guessing you'd have valuable personal property insurance, submit the claim...
Old Jul 9, 2020 | 03:17 PM
RX469's Avatar
RX469
Have you considered removing the seat she was sitting on and have a goo look all around and even under that seat? This is still easier than going the dashboard route.
Did either of you happen to hear the sound of the earring hitting the windshield/dashboard?
Old Jul 12, 2020 | 12:56 PM
JonGX's Avatar
JonGX
Thanks in advance.
im sorry about your misfortune but couldn’t help but to have a little chuckle to myself about what a first world problem this is. My diamond earring is lost in my Lexus...
Old Jul 12, 2020 | 02:31 PM
cb1111's Avatar
cb1111
Get a shop vac with a clean bag and vacuum all the crevices. Then cut the bag open and sift through the contents.
Old Jul 12, 2020 | 06:12 PM
tecman's Avatar
tecman
I accidentally swallowed my key fob so I will be doing something similar to this tomorrow.
Old Jul 12, 2020 | 07:16 PM
cb1111's Avatar
cb1111
Two liters of MoviPrep ought to do the trick.....
dougm213
Dec 2, 2014 05:45 AM
JH48
Dec 18, 2012 01:11 AM
Rash
Dec 11, 2007 09:29 PM
Skulinex
Aug 16, 2002 02:37 PM
