Plastics in engine bay
Old Dec 16, 2018 | 12:22 AM
konc3pt's Avatar
konc3pt
From: From Oakland to Sactown, the Bay Area & backdown
Default Plastics in engine bay
Talking about the silver engine cover and black radiator/front bay cover...do these have any functionality? Thinking about keeping them off
Old Dec 16, 2018 | 03:49 AM
Acrad's Avatar
Acrad
Aesthetics and I've heard it can suppress some engine noise but not sure this would be noticeable on the GX. The GX cover does have some padding in there so there may be something to that purpose.
Front bay cover probably probably just aesthetics and a place to rest your service caps. That one does get in the way of servicing radiator and power steering fluid....just to name a few.
Example off of eBay
Old Dec 16, 2018 | 11:32 AM
nuclearn8's Avatar
nuclearn8
sound dispersion, absorption, and deadening. Take it off and drive around. only you know if it's tolerable within the cabin.
Old Dec 16, 2018 | 11:36 AM
BradTank's Avatar
BradTank
I think it's probably 99% aesthetics and maybe a rounding error in sound absorption.
Old Dec 16, 2018 | 11:37 AM
bbqsoup's Avatar
bbqsoup
What’s the reason for taking it off? I like the look of the silver cover.
Old Dec 16, 2018 | 03:29 PM
John00's Avatar
John00
The major use is for sound reduction. Thats why some other manufacturers call it a sound absorber or acoustic cover. The looks part is secondary, the rectangles for each cylinder. Others use circles or actually state the number. Also gives a clean look
http://www.dupont.com/industries/aut...nnovation.html
Older engines aren't able to benefit from them for various reasons. These started out on super expensive vehicles with very high horsepower engines.
Old Dec 16, 2018 | 10:18 PM
konc3pt's Avatar
konc3pt
Thanks for the info, saw foam like material on the underside of the engine cover and wasn't sure if this thermal thing, sound absorber makes sense I suppose...took a peek under it and there was an old napkin and some leafs, it's capturing dirt plus I noticed an inch long crack on the right hand side so figured I'd take it off and maybe keep things cooler?
No offense to those who like the look of it, to me looks cheap, guess if your car is silver it blends in better...since this thing has a purpose I might repair the crack with epoxy and spray paint it black to match rest of the car better.
As for the front bay cover think I seen somebody on GXOR mentioned it helps to channel air better I'm not sure about that and if it's actually true.
Old Dec 17, 2018 | 03:06 PM
Craigyyy's Avatar
Craigyyy
If I took it off, then I'd have to find some place to store it...
GRAYM
GX - 1st Gen (2003-2009)
May 2, 2011 07:42 PM
jaxxx
Jan 6, 2011 01:28 PM
Shaar
Jan 12, 2009 09:48 AM
DXGS400
Sep 13, 2004 12:18 PM
