What #power #steering oil to use
Old Oct 16, 2023 | 11:36 AM
  #76
robd88's Avatar
robd88
Originally Posted by jonshonda
So I did my power steering flush this weekend and was anticipating the power steering pump to only pump fluid when turning the wheel, but that wasn't the case with my 2017. As soon as the engine started, the pump started pumping. Not sure if something changed via other models, but this is def a two man job. One starting engine, and the other manning the fluid level.
Just FYI, with the engine off, the fluid will be pumped when the steering wheel is turned. I don't start the engine when I do a power steering flush.
Old Oct 17, 2023 | 04:48 AM
  #77
jonshonda's Avatar
jonshonda
Well now ya tell me!! I got it done, just surprised me that it would start circulating fluid right away.
Old Oct 17, 2023 | 12:16 PM
  #78
SC3coupe's Avatar
SC3coupe
The factory fill is supposed to be Toyota 08886-01206
I know they specify ATF in the manuals..
Old Oct 17, 2023 | 01:50 PM
  #79
Seanzky's Avatar
Seanzky
That fluid has been discountiniued.
Old Mar 31, 2024 | 07:13 PM
  #80
Taysdad's Avatar
Taysdad
Changed the PS fluid on my 2017 this weekend at 57k miles. I used the Toyota ATF (highway robbery at $14/quart). The old fluid was black and smelled burnt. New fluid is bright red and clean. Used my Mityvac fluid extractor and pulled old fluid out of the return hose until new red fluid began to be removed (kept reservoir full of new fluid while this happening). It took just under two quarts for a full flush. The steering is again silky smooth and quiet. This only took about 15 mins to complete and I am a bit embarrassed I waited this long to do it. Very simple job with immediately satisfying results.
Old Mar 31, 2024 | 08:14 PM
  #81
For that price can use this fluid it is far superior
https://www.amsoil.com/p/amsoil-oe-m...ion-fluid-otf/
Old Dec 6, 2025 | 06:09 PM
  #82
Acrad's Avatar
Acrad
I had previously done the change and drive method via PS reservoir …. rinse/repeat until near full diluted fluid exchange had been performed. I had mentally missed tips that fluid circulation occurs with steering wheel movement even while off. I jacked up both sides and made for easy full power steering fluid exchange. I did around 10 full… left to right passes on steering wheel before the next fluid swaps.
Old Dec 7, 2025 | 03:15 PM
  #83
ASE's Avatar
ASE
... front wheels raised using jackstands ... or easier ... triple fold over plastic heavy duty yard waste bags and drive front tires onto the bags on a smooth garage floor ... very easy to steer thru full L-R lock ... close to as if on smooth ice. One L-R sweep with engine off comes close to emptying the reservoir if the return line is fed into a waste container.
dbui
RX - 1st Gen (1999-2003)
Jul 3, 2013 04:30 AM
imherenow
Dec 17, 2011 08:21 AM
wintondb
IS - 1st Gen (2001-2005)
Dec 12, 2011 06:38 AM
chestman88
Oct 19, 2011 04:22 PM
boris
Sep 3, 2009 12:55 AM
