What #power #steering oil to use
Old Jun 3, 2020 | 08:10 PM
  #46
nuclearn8's Avatar
nuclearn8
Originally Posted by LexusGXFan
Are you shining a light on the reservoir for the Amsoil to appear so pink ???
Yes sir. Without a light on the reservoir it is not possible to see the true color of the fluid (even brand new Amsoil inside the reservoir appears much darker than it actually is). If the reservoir is stained/ burnt from overheated fluid then a light doesn't help obviously...
Old Oct 11, 2020 | 03:31 PM
  #47
WRD4chano's Avatar
WRD4chano
will i cause damage if i turn the wheels while they are on the ground (i dont have jack stands yet)
this is whats inside my reservoir. looking at the service history, its never been touched.
https://drive.google.com/file/d/1bzb9MpG9h9rKRWFGjYnJtY77CXewaBfg/view?usp=sharing
i plan on using this method to get out some of that old fluid.
Old Oct 11, 2020 | 04:04 PM
  #48
Acrad's Avatar
Acrad
IMO: You could just use a floor jack in that front center area under skid plate. You aren't under the vehicle but still be careful around the lifted vehicle. I realize this is not an entirely safe scenario.
Still looking for graphic of location
Old Oct 11, 2020 | 04:18 PM
  #49
Acrad's Avatar
Acrad
I can't find the schematic tonight but it is this part of factory skid plate that contacts the frame in middle that is a lift point.
Old Oct 11, 2020 | 04:24 PM
  #50
nuclearn8's Avatar
nuclearn8
1st off good on you for checking this often neglected fluid, that looks like it needs a freshen up for sure.
You'd need to turn on the vehicle on to turn the wheels on the ground... is it possible?sure. It'll be much easier and less pressure in the system with the front wheels off the ground however. You could always just do extract and fills of the fluid with the vehicle off. One a day for a week (with a short drive in between) will get you 50% new fluid without the need for Jacks or lifting the front end off the ground. This is a super easy way to keep it the PS fluid fresh at minimal expense. The Amazon extractor I linked above works like a charm and with the amsoil easy pack ya dont need a funnel. Super easy. Good luck!
Old Oct 14, 2020 | 01:49 PM
  #51
LexusGXFan's Avatar
LexusGXFan
Default 2019 vs 2016 P/S Fluid
Doing my services on the 2019 GX and was going to do a suck and refill on the P/S Fluid in the reservoir. I was expecting to see a reddish ATF colored fluid, but to my surprise the fluid was brownish in color. My 2016 definitely has ATF for the system, but the 2019 appears to have a dedicated P/S fluid vs ATF.
All my manuals shows ATF for the P/S system.
The fluid is not burnt.
7700 miles on the 2019.
Thank you !
Old Oct 14, 2020 | 05:18 PM
  #52
Acrad's Avatar
Acrad
Perhaps some stock DEXRON II/III without the red coloring?
https://lexus2.custhelp.com/app/answ...lexus-vehicles
Even 2021 owners manual says DEXRON II or III
Old Oct 15, 2020 | 08:18 AM
  #53
nuclearn8's Avatar
nuclearn8
It doesn't take long for red ATF to turn brown... the color doesn't necessarily mean it needs to be changed.
Generally the odor or consistency of a fluid or the baking of the fluid on the sidewalls of the PS reservoir, in this case, is a clear cut indication it needs changed otherwise changing it at the owners manual frequency, or more frequently, is advisable.
The PS system operates at high pressure and with surprisingly little cooling (just that little solid tube routed in front of the radiator which loops down on each side by the frame rails.
Old Oct 16, 2020 | 09:56 AM
  #54
Jacket's Avatar
Jacket
Wow - 7700 miles and you are servicing the PS fluid?
Old Oct 16, 2020 | 10:02 AM
  #55
LexusGXFan's Avatar
LexusGXFan
Just sucking out what is in the reservoir at each oil change is all I'm doing
Old Oct 18, 2020 | 08:34 AM
  #56
angrygx's Avatar
angrygx
good choice!
Old Jan 8, 2021 | 07:50 PM
  #57
Acrad's Avatar
Acrad
Here is an alternate method
Old May 26, 2022 | 03:42 PM
  #58
ellocovg's Avatar
ellocovg
I know this is a old thread, but I didn’t want to clutter. How much are you guys paying for power steering, and coolant flushes at the dealer? I got the following quote from Prestige Lexus. I’m not sure if it’s my cheap soul but this seems a bit high.
“The coolant flush is a complete flush of the entire coolant system. It also uses an additive to clean out any kind of corrosion that may be in the system it would be around $383 and the power steering flush would be around $277. I can give you a loaner car for those service’s”
Old May 26, 2022 | 05:59 PM
  #59
Jacket's Avatar
Jacket
Seems reasonable.
Old May 26, 2022 | 08:38 PM
  #60
ASE's Avatar
ASE
Originally Posted by NewB2Lexus
There has to be a way to disconnect the return line, jack up the front and turn the steering wheel side to side to push the old fluid out. I don't have the GX with me to check but that's how I have done it in the past on all my trucks.
Exactly the right method ... flushes out the old fluid while replenishing with new fluid ... avoids the introduction of air into the system. Just need a helper to turn the steering wheel while watching the fluid level. Amazing how much fluid is pumped out with a little steering wheel movement. Takes about 2-3 Quarts for the purged fluid to be 90% clean ... depends on the age of the fliud being replaced.
