#High #Beam #LED replacement...
Old Jan 31, 2022 | 07:03 PM
  #226
tk8lm6's Avatar
tk8lm6
Default Auxito LED HighBeam Orientation
Hi There SamLexRXGX - I bought and installed these on my 2018 GX. When mine went in, the LEDs were on either side and the "substrate" I guess it is called, has a vertical orientation. DO you know if this is right? Or maybe the LEDs should be oriented top and bottom of the substrate? Any idea?
These things are bright and crisp white. One thing I always wonder about these devices that have an in-built fan ... the whole assembly fits INSIDE the headlight assembly which is sealed with that dust cover so even though it is fan-cooled, there is no outside air circulating. I guess it is ok. I am not inclined to leave the dust covers off of the high beam assembles.
But yeah, these things are nice.
Originally Posted by SamLexRXGX
https://auxito.com/collections/auxit...ml_High%20Beam
I used the auxito high beam. I feel its perfect replacement. working great.
it has 1:1 same beam pattern with the factory Halogen bulb. same focal length and position like the factory bulb.
Old Feb 1, 2022 | 08:54 AM
  #227
SamLexRXGX's Avatar
SamLexRXGX
You are right. it is vertical orientation. I have installed with the built in fan inside the dust cover. so far no issues. This probably helps inside the air circulation better. Removing dust cover was not recommended as it may result in humidity, water condensation etc.
Old Apr 3, 2023 | 11:34 AM
  #228
FolsomGX's Avatar
FolsomGX
5th Gear
Default 2016 GX460 High Beam Replacement
Searched first; didn't find much.
2016 GX460 luxury, HID low-beams, halogen high-beams. Looking to replace with LEDs. Seeing a lot of disparate info on bulbs, dust covers, etc. Any thoughts or suggestions are appreciated. Looking for maximum brightness/output for country roads. Not concerned about street legality; will only be on when not around other cars anyhow. Suggestions appreciated!
Old Apr 3, 2023 | 01:08 PM
  #229
Isn't the low beam already LED? If not what bulb does it take?
Old Apr 3, 2023 | 02:11 PM
  #230
FolsomGX's Avatar
FolsomGX
5th Gear
I'm looking to replace the (halogen) high-beam, not the low-beam.
Old Apr 3, 2023 | 03:07 PM
  #231
You mentioned HID low beam. Check out this channel (no affiliation)
https://www.youtube.com/@CarLightReviews
He publishes a spreadsheet which is very helpful
https://docs.google.com/spreadsheets...#gid=587956558
I have the Hikari 2023 Titanova on the way will be here tomorrow. I chose this one because it has better cooling than most. They make an H9 version
Amazon Amazon
Old Apr 3, 2023 | 03:10 PM
  #232
FolsomGX's Avatar
FolsomGX
5th Gear
https://www.amazon.com/dp/B0B1MGYT58/
I'm just looking to replace the halogen high beam. Now seeing that the low beam is factory LED, not HID.
On the Hikari, do they require extended dust covers, anti-flickr setups, or anything else? OR are they plug and play?
Old Apr 3, 2023 | 03:12 PM
  #233
They will not work if your car has DRL on the high beam meaning 6 volts. Only one I know of that does this is the Morimoto with anti flicker module. For applications like this I turn off DRL and enable the low beams to always be on via Techstream. Not sure this is possible on your truck.
Dust covers don't know would need to see the back of the headlight. Generally they can be an issue with any bulb that has a fan which is most.
Old Apr 3, 2023 | 03:16 PM
  #234
FolsomGX's Avatar
FolsomGX
5th Gear
The headlights have a separate LED DRL; the halogen beams aren't used for DRL that I can see. Since they're halogen, if there was any voltage in them, they'd light up.
What do you do with the dust covers on fan-LEDs? Just leave them off?
Old Apr 3, 2023 | 03:19 PM
  #235
That's good news, apologizes for not knowing exactly how your headlight is set up.
People do yes, long term it could mean dust and moisture potentially getting into the housing. Look at the bulb I linked to, the collar comes off can you put the rubber boot onto the bulb then put the collar back in place and have enough space?
Old Apr 3, 2023 | 03:33 PM
  #236
FolsomGX's Avatar
FolsomGX
5th Gear
I'll do some more looking on how much space I have. I was hoping to hit someone who had done this on this vehicle--but your responses are super helpful and much appreciated!
Old Apr 3, 2023 | 03:35 PM
  #237
That would be ideal. Not many people go LED because of a popular misconception that they don't work properly in a housing that originally had halogen or HID. Years ago this was true not anymore.
Old Mar 24, 2026 | 12:21 PM
  #238
Safariman's Avatar
Safariman
10th Gear
I just installed Hikari titanova H11 in the high beams. Everything fits within the factory dust cover.
These are retina roasters😳
jk08
Jan 17, 2018 11:15 AM
Milonga
Jul 23, 2017 05:30 PM
jimjaix
Jun 22, 2013 05:39 AM
wpbmed
Sep 20, 2011 05:04 PM
yoyokata
Jun 8, 2011 09:19 AM
