GX 460 - Glove Compartment Courtesy light change
Old 09-29-17, 07:13 AM
ngipay
ngipay's Avatar
Default GX 460 - Glove Compartment Courtesy light change
Anyone have instructions on how to remove the glove box for the GX 460 models? I'm looking into changing the courtesy bulb inside the glove box. Thanks
Old 09-29-17, 04:22 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,572 Likes on 2,338 Posts
Not sure if this helps or not.
Old 09-29-17, 04:38 PM
tecman
tecman's Avatar
I forgot that little wimpy output bulb was there. It is the same orange floor courtesy bulb I believe and someone here mentioned that you have to solider it in, So not easily replaced.
I installed this in my GX and a larger model in my home. I do experience frustrations with the photocell that I can't bypass (I want light and it will not activate due to some soft light shuts it down).
Amazon Amazon
Old 07-14-23, 08:58 AM
ronsatour5
3rd Gear
ronsatour5's Avatar
Default GX460 glove box light not working
Recently my 2010 GX460 glove compartment courtesy light stopped working. Does anyone have a procedure or information on accessing and testing it?
Old 07-15-23, 02:05 AM
GXWes
GXWes's Avatar
Wait, there’s a glovebox light on the GX?
That’s never worked on mine. Do you have to turn it on get it to work?
Old 07-15-23, 05:08 AM
ronsatour5
3rd Gear
ronsatour5's Avatar
My was working until this week. It is a yellow LED mounted left of center toward the opening.
Vied looking up. The left side of the registration strap is visible.
Old 07-15-23, 05:55 AM
Acrad
Super Moderator
Acrad's Avatar
There is some info about these types of bulb assemblies in this old thread as well
https://www.clublexus.com/forums/gx-...le-lights.html
YODAONE
02-03-17 09:33 AM
spoogenet
05-26-16 06:57 PM
Jcp90ls400
GX - 1st Gen (2004-2009)
01-10-11 08:26 PM
DAgreenSC
SC- 1st Gen (1992-2000)
09-27-07 11:09 AM
Quick Reply: GX 460 - Glove Compartment Courtesy light change
