#Differential and #Transfer #Case Fluid Change
Old Oct 30, 2019 | 07:27 AM
  #106
Chasin's Avatar
Chasin
Thanks guys. I've decided to go with Mobil 1 75w90 for the Diffs instead of the Redline. Where are you guys buying the Toyota 75w liquid gold fluid from? I need to buy 4 quarts (doing my GX and brothers 4runner).
Old Oct 30, 2019 | 07:50 AM
  #107
LexusGXFan's Avatar
LexusGXFan
I've ordered several times from TRDPARTS.COM
Free shipping over $100.
The price has gone up in the past 16 months, but still cheap insurance knowing YOU are doing the right thing by using the CORRECT fluid vs. what some dealers are using.
Old Oct 30, 2019 | 08:35 AM
  #108
nuclearn8's Avatar
nuclearn8
Originally Posted by Acrad
Changed transfer case fluid today.
• As I have seen elsewhere no magnet on drain plug. I was expecting this
@Acrad Do you see any value in adding a transfer case drain plug that has a magnet on it? I was going to get one of these Dimples https://drainplugmagnets.com/cars/toyota-lexus/ for the front diff (to swap out the 10mm hex drain bolt, loathe that design) on my next differential service since it's cheaper than the KOAN drain plug swap kit https://www.kaon.com.au/front-diff-t...toyota-hilux-k . While I'm ordering the dimple for the front diff I was thinking of picking up one of the transfer case as well...
Old Oct 30, 2019 | 08:51 AM
  #109
Romanova's Avatar
Romanova
I like Bell Lexus on eBay for all of my OEM parts, including the TC fluid.
Old Oct 30, 2019 | 02:36 PM
  #110
Acrad's Avatar
Acrad
That is where I originally got my fluid.
nuclearn8: I can't see that being a bad idea. I might do that next time when I service mine.
Old Oct 30, 2019 | 04:35 PM
  #111
LexusGXFan's Avatar
LexusGXFan
Which one would be for the transfer case on the plugs ??
Old Nov 1, 2019 | 07:34 AM
  #112
nuclearn8's Avatar
nuclearn8
M18 (all 6 plugs (fill and drain) are M18 except the front diff drain plug, which is M24)
Old Nov 1, 2019 | 10:19 AM
  #113
bbqsoup's Avatar
bbqsoup
Make sure you also get the gasket for the drain plugs.
https://www.ebay.com/itm/GASKET-KIT-....c100005.m1851
Old Nov 10, 2019 | 07:58 AM
  #114
LexusGXFan's Avatar
LexusGXFan
Default Redline MT-LV 70w/75w GL-4 Gear Oil (GX Transfer Case Fluid) Specs
I talked with Dave at RL and their new Low Viscosity fluid is recommended for the Toyota Transfer Case fluid we use in the GX.
Specs listed below
Boron - 9400 ppm
Zinc - 2600 ppm
Phosphorus - 2200 ppm
Calcium - 3300 ppm
These are impressive and are higher than the Toyota LF fluid and also the Ravenol MTF-3
Is anyone using this in the TC yet ?
Old Nov 10, 2019 | 08:29 AM
  #115
nuclearn8's Avatar
nuclearn8
Interesting. I plan to stick with the Toyota fluid until they release a compatible spec for acceptable alternative fluids, like for the differentials. The transfer case is expensive, the fluid is not.
Old Nov 11, 2019 | 07:04 AM
  #116
Jacket's Avatar
Jacket
That's good news. I've got Redline GL5 gear oil in my GX's diffs, and have always run it in past vehicles whenever feasible. At $17.75 a quart, it's expensive as far as MT oils go, but a bargain compared to Toyota's branded TCase oil. I'd run it without concern.
Old Nov 24, 2019 | 07:28 AM
  #117
william489's Avatar
william489
Thank you everyone who posted part numbers, photos and advice here.
I just did rear diff fluid change this weekend for my 2015 GX Premium (60K miles), it is indeed dirty, what came out from rear drain plug is milky/dusty oil. I would be surprised if I have not read this here first.
I think 40:60 power split between front/back (normal pavement) explains this a bit. I only do pavement driving with no towing or OR, so I am bit at loss why lexus doesn't recommend this at 60K service interval.
Old Dec 16, 2019 | 06:20 AM
  #118
natehack's Avatar
natehack
https://www.redlineoil.com/mt-lv-70w75w
Not sure how long this fluid has been around, but I may just give it a go.
Will do some more research since I do not remember reading anything about it before.
Old Dec 16, 2019 | 06:51 AM
  #119
NewB2Lexus's Avatar
NewB2Lexus
Exclamation
This fluid is GL-4 while the SM calls for GL-5. But of course it is your truck, you can use whatever you want!
Old Dec 16, 2019 | 07:00 AM
  #120
natehack's Avatar
natehack
Well crap, true enough
OEM it is!
