Drivers Window
Old Jan 22, 2026 | 09:59 AM
CFAI's Avatar
CFAI
Default Drivers Window
My drivers window seems to make a sort of buffeting sound at speeds at or over 40 miles an hour - all windows are closed. If I press on the window at those speeds with my finger the sound stops. I tried jamming some small cut up pieces of weather stripping from Home Depot into the window molding as a way to try to apply some extra pressure on the window but that didn't really work. Any suggestions? If there isn't an easy DYI (and I mean EASY - I am not pulling the door card) - where would be a good place to get it sorted? A auto glass shop, autobody, dealer etc. Most people woulndt really notice of be bothered, but it drives me a little crazy.
Old Jan 22, 2026 | 12:22 PM
PennwestPatrick's Avatar
PennwestPatrick
Possibly try to reset the limit? Maybe the windows is stopping before it should.
Someone will explain the possess to try this first.
Old Jan 23, 2026 | 08:48 AM
nuclearn8's Avatar
nuclearn8
Our has done this since we bought it in 2019. I've tried numerous things and nothing has worked . I just consider it a quirk of the vehicle. It's only really noticeable at high vehicle speed and significant crosswinds that I've noticed on ours
Old Jan 23, 2026 | 05:23 PM
CFAI's Avatar
CFAI
But it drives me crazy - I do find that if I open the sun roof it goes away.
Old Jan 24, 2026 | 06:07 AM
Toejab's Avatar
Toejab
opening the sunroof makes it go away now that's just bizarre. I would think that the noise coming in to the sunroof would be more annoying than a window rattling. Are you sure that that window is totally up and pressing into its frame? If not there's a process for resetting your window . I believe all you do is hold on the down button till it goes all the way down and then hold it for 4 seconds then push the up button and hold it there while it's totally closed for 4 seconds do that a couple times and it's supposed to reset the limits
Old Jan 24, 2026 | 07:24 AM
CFAI's Avatar
CFAI
I will check that. Thanks. Fingers crossed that it all it is - bc it drives me bonkers.
Old Jan 25, 2026 | 07:30 AM
CFAI's Avatar
CFAI
I search for this online and is this the procedure where you have to take the motor out? Maybe an autobody place might be best?
beachit321
Feb 28, 2018 06:54 PM
Calicraig2
Sep 26, 2016 09:39 AM
Duker3
Aug 26, 2016 09:01 AM
Helogadget
May 16, 2015 08:38 AM
