First time posting...
I have a 2005 ES 330. Tonight the driver's window would not roll up or down. The light on the button flashes. I have tried resetting as described in other posts but that didn't work. The other 3 windows and the sunroof work. Any ideas?
Thanks in advance!
Thanks in advance!
Are you able to wiggle the window glass? Might be regulator +/- glass off track, or the cable. Either way you may be looking at replacing regulator +/- window. It is possible if the window slightly went off track, track might be slightly bent and you may even have a crack in the windshield. I have had this happen on my honda. But the repair is not costly though.
Edit: Sometimes it could just be a loose connection. I just remembered that on the corolla this sometimes happens. The window operates correctly. Then just stops. Works again after some time. It could be the assembly. I just unscrewed it, pressed in the connectors and that was it. Electronics.
