Understanding Tire PSI
Hope everyone’s having a great day!
I’ve been really enjoying my new-to-me 2020 GX460 with the 19" wheel sport package. When I bought it, it came with new 275/55/19 Nitto Motivo 365 tires, and I just noticed they were set to 42 PSI. While washing the car, I saw that the door sticker recommends 32 PSI. Should I lower the tire pressure to 32 PSI to match the manufacturer’s recommendation?
Additionally, I purchased 18" OEM tires for $400 locally and plan to buy Falken Wildpeak A/T4W in the future. What is the recommended daily PSI for ATs for daily driving?
Tire ply refers to the layers of material that make up the structure of a tire, providing strength and support. Each layer, or ply, contributes to the tire's ability to carry loads and maintain its shape while in use. copied from google
higher ply count means stiffer ride, stronger tire, higher sidewall strength, higher load capability, often used at higher psi, often longer life, often used on trucks
lower count gives softer ride, lower sidewall strength, lower load capability, often used at lower psi, often shorter life, often used on cars
comfort is personal. some use comfort to mean floaty, soft while others use comfort to mean more road feedback (seats not wheel).
can put higher psi into low plys or lower psi into high plys, theres some overlap in parameters to get certain cushiness values (based on the tire and not the suspension)
... all "tires" are not created equally ... meaning size and construction (load rating). Just because "tires" are on a "GX460" does not mean psi can be universally applied based on random forum input.
this entire conversation made me realize that you really cannot go by that sticker on the door frame because the PSIs that you use in your tire depends on the actual tire that you put on the vehicle. In other words standard load rating versus LT rating of the tire in question. So I would suggest going with what it says on the actual sidewall of the tire not what it says on the door frame.
