SRS Code Help - B1865 Knee Squib Circuit
Old Dec 27, 2024 | 09:33 AM
Chewyeti's Avatar
Chewyeti
4th Gear
Default SRS Code Help - B1865 Knee Squib Circuit
Hi All,
New to this forum, but active on IH8MUD and GXOR. My 2018 recently gave me an SRS warning light so I used tech stream to pull the B1865 Code.
Seems this has to do with the Passenger side knee squib airbag circuit.
Here's the interesting thing - it's temperature related!
When the weather is cold (Sub ~65* F) the light comes on and stays on a startup.
If it warms up throughout the day and the GX is started, the warning light does not latch after the first 6 seconds (Initial SRS system check).
Where to start? Has anyone had this before? (I searched and couldnt find any mention of this code)
The intermittent nature is interesting, connection or wire condition issue?
I've looked at the FSM and am hesitant to try and diagnose beyond checking connections behind interior panels. The manual shows a special wiring tool to check some connections without setting off the airbags....
Any help would be mightily appreciated!
Thank you in advance
AC
File Type: pdf
File Type: pdf
Old Dec 27, 2024 | 03:16 PM
John00's Avatar
John00
there could be moisture that condenses in cooler temps that causes a low resistance to be detected and trigger the dtc. cracks in insulation can cause this. seen it in ignition coils also. when fails in cold or when it rained overnight, a hairdryer on low was used to dry it out and demonstrate the problem area.
might also be some other problem such as violating minimum electrical spacing based on coefficient of thermal expansion differences.
if me i would disconnect the battery, then measure the squib resistance. checking at the beginning so there then the sensor.
usually the sst is so you dont accidentally connect wires you shouldnt.
Old Dec 28, 2024 | 10:11 AM
IntrinoX's Avatar
IntrinoX
Have you messed with the plug at all?
Old Dec 29, 2024 | 06:28 PM
Chewyeti's Avatar
Chewyeti
4th Gear
Yeah, this is my plan. I will pull the interior pieces by the knee airbag and clean the terminals with contact cleaner and reseat the connector.
I made a 2.1 ohm "SST" tool to further trouble shoot if that doesnt solve the issue.
Old Feb 9, 2025 | 03:14 PM
rex450's Avatar
rex450
4th Gear
I had the same DTC's + driver knee airbag [rx450h]. Funny thing, that those lights came on & off randomly. Sometimes starting car again helped.
I also thought this is temp or moistrure related. I even bought a multimeter to check the harness.
And guess what was causing the christmass tree problems.... cheap phone charger! After some time, probably some parts got overheated and started to "poluting" 12v current. Since I got rid of it, its fine.
fun fact: my Honda do not mind me using this charger
LexusK
Jul 25, 2024 08:26 AM
allday123
Jun 14, 2022 05:02 AM
RCsGX
GX - 1st Gen (2003-2009)
Mar 7, 2014 12:44 PM
S142jz
Jun 28, 2010 10:18 AM
g3t0ut
Mar 20, 2009 11:42 PM
