Vibration
Old Dec 3, 2024 | 12:11 PM
Supersizeal's Avatar
Supersizeal
9th Gear
Default Vibration
Anyone getting vibration in the steering wheel during highway speeds after lift with bigger tires?
Rebalance wheels and tires?
Drive Shaft?
Hoping to get some advice on this matter.
thanks!
Old Dec 3, 2024 | 12:36 PM
ASE's Avatar
ASE
"Bigger Tires" = Heavier ... so even more a reason for Road Force Balancing ... something that IMO is mandatory for the Toyota Body-on-Frame platform.
Also, does "bigger tires" also mean aftermarket wheels ? ... that are hopefully "Hub Centric" (106.1mm) ?
Old Dec 3, 2024 | 01:27 PM
Acrad's Avatar
Acrad
A few thread you might want to look through:
https://www.clublexus.com/forums/gx-...ke-issues.html
https://www.clublexus.com/forums/gx-...yes-or-no.html
https://www.clublexus.com/forums/gx-...nder-load.html
#vibration
Old Dec 4, 2024 | 12:35 PM
NewB2Lexus's Avatar
NewB2Lexus
If the vibration was not there before upgrading to bigger tires and the steering wheel wobbles (side to side) then the most likely cause is the lateral runout of the (aftermarket ???) rims.
Old Dec 5, 2024 | 10:22 AM
ASE's Avatar
ASE
Start with Road-Force-Balancing ... will pinpoint issue ... imbalance, out-of-round, runout ... plus is simply more accurate given the the tire is loaded during the process.
501moser
Suspension
Dec 31, 2020 12:50 PM
coloboardi
GX - 1st Gen (2003-2009)
Nov 25, 2014 03:27 PM
dbui
RX - 1st Gen (1999-2003)
Dec 19, 2011 05:26 AM
hmkim
May 19, 2010 09:56 PM
spaniola
Aug 4, 2006 08:39 AM
