#Vibration through steering wheel when under load?
My mechanic that has 50 years' experience drove my 22 gx, felt the humming on acceleration and put it up on a lift. He went right towards the motor mounts and trans mounts. We found that the passenger motor mount to be either faulty, defective, soft or weak. My opinion is the rubber has changed over the last few years as we have had global supply chain problems. The mount certainly has play in it and the driver side mount is tight and good. Explained this to Lexus and they looked at me like I had 3 heads. Lexus is not qualified to find a simple faulty mount, nor do they want to replace it. Is a matter of fact, they said we have never replaced a motor mount before and pushed me out the door. We are basically screwed unless there is a recall! My mechanic says that it is not normal, and the humming is most likely due to the passenger motor mount.
For the group, has anyone driven a new one (2023) that doesn't do this ? Maybe this is normal (ie all of them do it). Most pronounced at about 1800 rpm under load. One other question to the group, do you think the wood steering wheel is causing this ? I have that option and was curious if that exaggerates any vibrations present in the driveline. Hopefully we can figure this out.
A GX motor motor mount is only $100, and is not hard to replace. Just do it and see what happens if you think the guy is right. Who knows, he may be.
Mark
I just put the car in neutral and revved it through 1500 to 1900 rpm and felt the buzz/vibration in the steering wheel (granted a little less then when under load). So this rules out driveline I think. Mounts makes sense but on our cars that are basically brand new ? It's also possible that the mounts are too hard. Apparently a very stiff mount can transfer vibrations also. The puzzling thing is that at idle or anywhere above 2000 rpm, there is no buzz/vibration. If it was mounts, wouldn't the issue be there all the time to some degree ? What the dealership should do is lift a new GX460 that does not have the issue and compare the engine and trans mounts to our cars that have the issue. That would probably confirm whether the mounts are the cure here. Also, worth noting for others readying this - the issue is really minor - my wife doesn't even notice (or care) but for a luxury SUV, you should not feel this.
I have noticed that when I am stopped at the red lights, waiting for lights to turn green and a car with a loud muffler drives by, I feel this exact buzz/vibration in the steering wheel. Loud sound waves cause it for sure and I think that our muffler has something to do with it. The steering wheel is "resonating".
My guess is, they modified and header or exhaust to make it slightly freer flowing or more aggressive. I did notice that engine is more responsive and revs more freely vs my 2018. Part throttle acceleration in my 22 is so much better vs the 18 as well.
I am feeling the exact same thing and I did exactly as you did. I put the vehicle in Park, revved the engine to around 1900 RPM and I could feel it. It is not a tire, CV axle, transmission, etc. issue. The bad part is the vehicle sits in this RPM range cruising on the highway. I thought it might get better as the vehicle broke in, otherwise, I would have returned the vehicle the next day.
I think there’s something going on with the build quality of these late 2023 GX’s. Also having a vibration issue at 60+ mph, but got blew off by the service advisor when I asked about it.
Here’s clip of someone else’s experience with it. Might be useful for the Massachusetts folks.
https://youtu.be/3MU5r53if5I?si=qUpCz0JlEpZ0b9vA
I started the arbitration process today with Lexus.
