Engine #Oil #Filter Adapter #Torque Spec
Old Mar 30, 2023 | 07:54 PM
robd88's Avatar
robd88
Default Engine #Oil #Filter Adapter #Torque Spec
I looked through the torque specs FAQ for the Engine Oil Filter Adapter (15609-38030) torque specs and saw two potential listings. I need the torque spec for the two bolts and the one nut that fits on the stud to mount the adapter to the block. One listing shows 15 N*m and another shows 35 N*m. Would anyone know which one is correct? Or if neither are correct and it is something else?
Old Mar 30, 2023 | 08:56 PM
mike202's Avatar
mike202
15 N-m is the torque for the oil pressure switch to bracket and 35 N-m is the bracket to cover torque.
Old Mar 30, 2023 | 09:07 PM
ASE's Avatar
ASE
Worth checking standard torque recommendations for the size metric bolt into aluminum ... as a sanity check. Also note that torque specs assume dry assembly ... meaning no lubrication.
Old Apr 3, 2023 | 07:11 AM
Acrad's Avatar
Acrad
Old Apr 3, 2023 | 08:42 AM
robd88's Avatar
robd88
Thanks for the responses confirming the torque. I was under there this weekend and without removing the fan, I didn't see a way that a torque wrench can even fit in there. Not much room in that area with the hard tubing right next to the adapter.
Has anyone had success removing and replacing the adapter? Seems like it may be more involved than just those 3 bolts.
ptetra
CT 200h Model (2011-2017)
13
Oct 2, 2022 06:59 AM
RA92525
May 10, 2022 03:47 AM
HadYurPhil
RX - 1st Gen (1999-2003)
16
Aug 6, 2018 05:24 AM
Dommm
May 8, 2017 05:32 AM
larrysb
IS F (2008-2014)
Aug 31, 2008 10:45 AM
