Engine oil filter?
Old May 6, 2017 | 09:46 AM
Dommm's Avatar
Dommm
Default Engine oil filter?
So I just did a DIY engine oil & oil filter change on my 2004 ES330. Is it OK to hand tighten the engine oil filter or does it need more force then just hand tightening? Thanks
Old May 6, 2017 | 11:48 AM
HomerJay's Avatar
HomerJay
Hand-tighten is recommended for most oil filters. Always check for leaks with the engine running afterwards,
Old May 6, 2017 | 11:49 AM
https://www.google.com/search?q=hand...ine+oil+filter
Old May 6, 2017 | 11:53 AM
Dommm's Avatar
Dommm
Thanks for that
Dommm's Avatar
Dommm
Thanks for that
Old May 6, 2017 | 06:56 PM
ES300NZ's Avatar
ES300NZ
oil filters should always be hand tightened, but must have fresh engine oil on the seal or it will leak without doubt.
Old May 6, 2017 | 07:02 PM
Dommm's Avatar
Dommm
Thank you
Old May 6, 2017 | 10:38 PM
nsghtbrwry's Avatar
nsghtbrwry
I installed a Denso oil filter and 5 quarts of Pennzoil full synthetic in my freshly-sealed '99 recently...took a pic of the instructions on the Denso box. See attached.
Old May 6, 2017 | 10:49 PM
crwys's Avatar
crwys
I change my oil and filter every 3k miles. Never had any leaks.
Dip your finger in your new oil
Spread the oil along the rubber seal on the filter
Hand tighten just about as tight as you can
Done
Old May 7, 2017 | 05:12 AM
Dommm's Avatar
Dommm
Thank you
Old May 7, 2017 | 05:14 AM
Dommm's Avatar
Dommm
Done
Thanks to you & everyone for your reply's. It seems a good hand tightening is called for & that's what I did.
Old May 8, 2017 | 05:32 AM
BDSL's Avatar
BDSL
I do hand tightening as well. I also don't go too crazy. If I hand tightening too much, once the gasket expands slightly, the filter takes a lot more effort to loosen.
DocT
LX - 3rd Gen (2008-2021)
45
Dec 22, 2017 07:23 PM
Fritz330
13
Jul 16, 2014 11:00 PM
GRPFAN
RX - 3rd Gen (2010-2015)
Aug 7, 2012 11:17 AM
dmight
Aug 31, 2011 12:29 PM
love67
Jul 4, 2009 01:37 AM
