Finding OEM 2022 wheel offset
Old Mar 20, 2023 | 01:50 PM
tqh's Avatar
tqh
Default Finding OEM 2022 wheel offset
Hi, I'm trying to find the wheel offset of my oem wheels. Looking at the back of the wheels I can see these markings: "25 BRM" "19x7 1/2J" "22/3" "J DOT". Only the "19x7 1/2" makes sense - I don't understand what the rest mean. I believe I need to find something with ET, right? Am I looking at the wrong place? Thank you!
Old Mar 20, 2023 | 03:33 PM
Siblue's Avatar
Siblue
25 sounds like the offset with those marking.
Old Mar 20, 2023 | 04:54 PM
JZZFZZ's Avatar
JZZFZZ
Made in March 2022. Not sure what BRM means.
Old Mar 22, 2023 | 04:55 PM
robd88's Avatar
robd88
From my understanding, the 2022 GX has either 18x7.5 or 19x8 wheels...both with +25 ET (offset).
Old Mar 25, 2023 | 05:51 AM
ACCGuy's Avatar
ACCGuy
5th Gear
+25mm is correct, at least for the stock Premium wheels. If your wheels are off the vehicle, and tires off the wheels, it's easy to measure yourself (all dimensions are in mm):
  1. Measure the overall wheel width. Should be 220mm.
  2. Divide overall wheel width by 2 to get distance to wheel center. So, 110mm.
  3. Measure the backspacing: With the wheel lying on its side, inside of the wheel facing up, lay a straightedge across the top of the wheel. Place the end of your ruler on the flat mounting pad (where the wheel mounts to the hub) and measure from there up to the bottom of the straightedge. Should be 135mm.
  4. To get the offset, subtract the distance to wheel center from the backspacing: 135mm - 110mm = +25mm. Notice this is a positive offset because when the wheel is upright and mounted, the mounting pad is towards the outside of the vehicle with respect to the wheel centerline. If the mounting pad was towards the inside of the vehicle with respect the wheel centerline, it'd be a negative offset.
Old Mar 25, 2023 | 08:56 AM
Rockstar08's Avatar
Rockstar08
Does anyone know how much the stock 18” rims weigh also?
Old Mar 30, 2023 | 07:48 PM
m5rahul's Avatar
m5rahul
Non F-Sport OEM 18s.. +25mm
F-Sport OEM 18s.. +20mm
Old Mar 31, 2023 | 08:49 AM
m5rahul's Avatar
m5rahul
~ 32 lbs (31.9ish)
Old Apr 2, 2023 | 08:57 PM
BlackAngus's Avatar
BlackAngus
thanks for all the above info!
Parsa
Jan 2, 2023 05:55 AM
Seattle SCone
RC - 1st Gen (2015-present)
Mar 12, 2021 06:34 PM
Northevo
Mar 24, 2015 07:13 PM
