GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
2004 GX470 Window Issue
Old 07-09-13, 01:16 PM
Crispy3M
Crispy3M's Avatar
Originally Posted by fmcgorman
Ok - my mistake. The power windows may not work from the drivers console but the windows lockout does. Hit the unlock from the drivers console and normalized the wind I windows. Thanks.
Awesome!
Old 03-27-15, 02:47 PM
tnblacktie
tnblacktie's Avatar
Default Thank you!
Originally Posted by mann777
If the battery is disconnected or run down
The power windows may not operate automatically and the jam protection function will not function correctly after you reconnect, replace or recharge the battery. At this time, the indicator lights of the switches will flash. In any of these cases,you should normalize the power windows.
To normalize the power windows:
1. Push down the power window switches of each door and
lower the windows halfway.
2.2. Pull up the switches until the windows close and hold the
switches for a second.
Make sure that the windows open and close automatically.
Also further is the clock and the Radio stations.
Hope this helps
I replaced the battery in my wife's 2008 GX470. When I noticed that only the driver window worked from the master control & couldn't locate the issue in the manual, I texted a Friend who sells Lexus for advice & fully described the issue. He responded that his tech said it's a common problem & it needs a new Master Control Module... about a $400-$500 job. I found this forum post while shopping for the module. You saved me a lot of money!
Why wouldn't a Lexus tech know to do this?
Old 03-30-15, 08:38 AM
chiph9
chiph9's Avatar
He's probably used to only getting the really tough problems. Something like this would likely have been solved by the Service Adviser and never booked into the shop.
Chip H.
Old 09-24-16, 04:53 PM
08gx470v8
08gx470v8's Avatar
As always, very helpful!
Old 09-30-16, 11:46 AM
AxelLexus
AxelLexus's Avatar
Same problem with my GX470 2004 it worked like magic, Thank you
Old 12-19-16, 04:00 PM
jayhawk89
jayhawk89's Avatar
An older thread here, but I'm another satisfied user. Wife's old '03 GX (about to hit 200K) just had a battery die. I swapped it out and wondered what was wrong with the windows. Lo and behold...this solution solved the problem. Thanks, Folks!
Old 12-19-16, 05:31 PM
ALAN553
ALAN553's Avatar
i guess lexus was tired of answering this question too, my 09 has a sticker under the hood right by the battery with instructions for initializing the windows.
Jbthompson
08-24-18 10:33 AM
tarnold
01-31-14 03:48 PM
gusung75
10-04-10 11:21 AM
Chris98vob
05-27-09 08:49 AM
danorat
RX - 1st Gen (1999-2003)
09-13-07 01:26 PM
Quick Reply: 2004 GX470 Window Issue
