Rear Power Outlet
Old Feb 24, 2021 | 10:15 AM
gwebster's Avatar
gwebster
Default Rear Power Outlet
Hi, I just realized that my rear power outlet is not working. I found the fuse, and it is blown. I put another fuse in and it blows immediately when I push the switch below steering wheel to turn on rear power. Must be a short somewhere as nothing is plugged in to the outlet. Would the most likely location of the short be the outlet itself? Also, can someone confirm the location of the high voltage converter- is it near the rear outlet behind the panel? This is not a huge issue to me, but I may try to fix on my own if I can determine where the short is located. Thanks!
Old Feb 24, 2021 | 03:18 PM
IanB2's Avatar
IanB2
I think the converter is in the back behind the cargo area side panel on the passenger side.
Old Feb 24, 2021 | 04:47 PM
chiph9's Avatar
chiph9
You can see the inverter in this photo from another post:
https://www.clublexus.com/forums/gx-...l#post10999003
It's the square box above the fan, to the right of the subwoofer.
Chip H.
Old Feb 25, 2021 | 06:58 PM
gwebster's Avatar
gwebster
Thank you for the help! Coincidentally, I also have a problem with the carpet getting wet in the back, so I will check out the rear A/C drain when I remove the panel to inspect the outlet and power inverter.
babaijebu
Feb 24, 2021 12:23 PM
SpruceRain
Nov 11, 2019 09:20 PM
Mantist
Jun 22, 2019 09:58 AM
rctm8UC
RX - 3rd Gen (2010-2015)
Jun 25, 2018 12:09 PM
