electrical issues - different inside cabin issues
Old Feb 20, 2019 | 04:38 PM
rlleblanc's Avatar
rlleblanc
Angry electrical issues - different inside cabin issues
Went on vacation, came home, started car (2007 gx) and all kinds of things weren't working. Power mirrors won't adjust. the memory settings for drivers won't work, in the display the backup display won't turn on, on the switches for the display, the menu, dest, map won't work but the display, info, audio and climate do and all those functions work normal. Also after driving for a few minutes on the display screen I get spaced vertical lines across the screen.
the lights that are on, on the dash - vsc trac, vsc off, and the the traction control (little car with the swerves under it) are all on.
i've check fuses, not finding any out..
Any ideas or thoughts.
Thank you!
Old Feb 20, 2019 | 04:46 PM
chiph9's Avatar
chiph9
Sounds like the computers are freaking out.
Try disconnecting the negative terminal from the battery, waiting about 5 minutes, then reconnecting with a minimum of sparks.
Chip H.
Old Feb 20, 2019 | 04:54 PM
rlleblanc's Avatar
rlleblanc
I will and let you know....thank you...
randy
Rx350T
Dec 12, 2018 12:30 PM
mydawgz
Jul 31, 2012 01:08 AM
edwinbong
Jul 18, 2009 03:36 PM
JohnGS4
Feb 27, 2008 07:30 PM
