Inside back door handle pulls out
Old Feb 14, 2019 | 02:25 PM
BHbass59's Avatar
BHbass59
Default Inside back door handle pulls out
Hi all - the inside back door handle on the 470 pulls out when applying any pressure to it - anyone have any ideas for quick fixes, short of buying replacement? I do not want to permanently install it (e.g., epoxy or some such thing) as I imagine the rear may have to come off from time to time.
Old Feb 14, 2019 | 02:46 PM
vwynn's Avatar
vwynn
common problem with many fix ideas. Some people used wall anchors with 550 cord.
If you do a search you will find different clever ideas.
Old Feb 14, 2019 | 03:26 PM
BHbass59's Avatar
BHbass59
Thx - I must not be doing something right using the search function as I couldn't find anything - that was my first thought. I'll try again and see if can figure out how to get better results.
Old Feb 14, 2019 | 03:30 PM
chiph9's Avatar
chiph9
This is the cargo door handle?
On each side of the handle (the hinges) there are two clips molded into the hinge. There's another part which acts as a wedge and pushes them apart and assures they get a grip on the metal.
If the clips are broken off (like mine did when I changed the backup bulb), ordering a new handle is the only solution unless you want to "bubba" it.
Suggestion: Change the backup bulbs before putting the new handle on so you'll never have to remove it again.
Chip H.
Old Feb 14, 2019 | 03:33 PM
BHbass59's Avatar
BHbass59
Chip H.
Thx - I'll take a look tomorrow and see if they've broken off. In my case, I removed the back panel to get at a license plate bolt that had seized.
Old Feb 14, 2019 | 04:30 PM
vwynn's Avatar
vwynn
https://m.facebook.com/groups/838842...73683386096108
Old Feb 14, 2019 | 04:38 PM
BHbass59's Avatar
BHbass59
Thx Matt - this looks great! I don't see a listing on their site for Lexus, only Jeep. I'll contact them and see what they say, I'm sure I can figure it out by size.
Old Feb 15, 2019 | 08:37 AM
vwynn's Avatar
vwynn
Its most likely universal. Just measure the length from center of plastic clip to center of plastic clip and maybe add 2 inches so the handle has a curve when installing. Its installed using wall anchors.
Old Feb 20, 2019 | 07:04 PM
campfire's Avatar
campfire
Mine failed too, the tab on the handle on the passenger side is broken off. I think I may go with led bulbs in the rear and attach it permanently.
Old Feb 21, 2019 | 02:29 AM
tifxng's Avatar
tifxng
10th Gear
For what it's worth, getting a replacement is fairly inexpensive. I bought a brand new OEM cargo door handle after mine broke a few months ago on eBay for 23 bucks
Old Feb 22, 2019 | 07:12 PM
Skyfox16's Avatar
Skyfox16
I bought an oem replacement handle from eBay as well. It was pretty cheap.
I got it to stick on after smacking it a few times to get it to clip into the holes but then then it popped back off after a few pulls so I left it off until I find a better solution.
justinp95
Sep 27, 2021 03:49 PM
Zacharias
Mar 3, 2016 10:09 AM
Helogadget
Jul 1, 2015 03:12 AM
LEXZILLA
Mar 4, 2008 05:32 AM
ES3
Nov 13, 2007 06:35 AM
