Need help with the factory bluetooth in my 07 GX. Often wondered about an upgrade. Those I call tell me I cut out about half of every conversation. Any worthwhile upgrade available?
Chiph9, Thank you. Order placed.
Kelevra, at the link provided, product information says works seemlessly with factory controls. As does video.
Yes, I understand. My post was to say it is for BT music from your device, It does not add another BT "Hands Free" phone connection.
Let us know how it works for you.
Well boys, I'm going to install it, and then put it to the test. Will report back. Stay tuned.
I have a 2004 gx470 mark levenson [ No blue tooth phone capability ] I installed the vias unit so I could access my phones music library as well as Pandora or any music streaming app. I installed it works fine you just have to make play lists with a number not a name like 1 or 2 or 3 or 4 etc can hold up to 999 songs per playlist.
I have a garmin gps and I make blue tooth calls through it and when I do vias will turn volume off on music and then back on when I disconnect call
You have to love k on u tube for a video on how to pull the radio it’s not difficult you just have to be carful when you pull the wood side panels use a clip pry tool it explains it in the video
Got it. Looks like the soundlinq3 also has a USB port for a power source for your phone. Kind of cool. Since this is present, I'll get a mount for my iphone6+. Any suggestions? Pics?
I agree. If you look on the product information page at the Vaistech website, you see this:
"What level of sound quality should I expect from the SL3b-L? The SL3b-L uses one of the best Bluetooth modules on the market, so sound quality is similar to Bluetooth streaming devices installed on new Toyota and Lexus models."
I think this has to be the reason some use it to upgrade the somewhat lacking factory unit in the older GXs, as am I.
