GX470 Overheating at stop
Old Jul 12, 2018 | 08:42 AM
coopRC350's Avatar
coopRC350
Default GX470 Overheating at stop
Hello all, this is my first post here. I own a 2015 RC350, 2016 IS 350 F-Sport and my most recent purchase a 2004 GX470. It has 139K on it and is in great condition. The previous owner had pretty decent service records, so i pulled the trigger. Yesterday, while I was driving I noticed the temp gauge was normal until i stopped. Then it would slowly creep up almost to the H. I shut it down and let it cool, but while moving of course with the extra air flow the temp is steady in the normal range. I get home and crawl under and notice a few things.
1) there is an unknown oil on the metal undercarriage. Cant tell how long it has been there or even what fluid it is. Didn't have a smell of engine oil, not really much of a smell at all, but i do have terrible allergies this time of year lol. Also, no leaks were on the ground where it was parked. It is located under the trans/backside of the oil pan area. Since there was lots of dirt accumulated and i couldn't tell what it was or where it was coming from, I wiped the areas clean for further observation...thoughts?
2)Checked the coolant reservoir and saw it was below the L mark when hot, waited until it was cool and it was still under the L. I topped off the fluids and started the engine. At idle, the engine was still steadily creeping up in temp and the fan would erratically kick on and off. A/C was on full blast as well.
I have an appointment tomorrow at a Toyota dealer, since there are no lexus dealers in the area, but i want to get some insight from the pros. In my research, i have seen the radiator and transfer case are common issues. Does any of what I've described fit your experiences?
Old Jul 12, 2018 | 11:27 AM
EddieK05's Avatar
EddieK05
1) Sounds like the transfer case actuator is leaking which is not an uncommon issue. Do a search on here and you will find many articles.
2) To me, it sounds to me like a bad water pump, especially if your radiator is not leaking. Did the timing belt and water pump get replaced yet?
Old Jul 12, 2018 | 12:00 PM
coopRC350's Avatar
coopRC350
I did see the transfer case threads also. Any idea what that runs at the Toyota dealer? ballpark at least? I am pretty mechanically inclined but it's hot as i don't know what down here, so if it is reasonable, i'll have someone else do it.
The previous owner stated he had the timing belt done at the time of my purchase, but i can't really vouch for that. Water pump should've been done at the same time, correct? I just bought this thing as a kid hauler, but i will need it soon. Just wanted to go armed with info for the dealer visit tomorrow.
Thanks for the reply.
Old Jul 12, 2018 | 12:13 PM
EddieK05's Avatar
EddieK05
From what others have posted, a dealer is going to charge $2K+ for the actuator replacement. What others have done is replace the o-ring in the actuator. Since you're mechanically inclined, I'd go that route.
Most of the time, yes, the water pump is replaced at the same time as the timing belt, but that's not to say it was in your case. Your overheating problem sounds like the same exact issue I had when I owned a Vette. Overheating at stops, temps ok when moving, and no signs of a visible leak. It was a bad water pump.
Old Jul 12, 2018 | 12:50 PM
coopRC350's Avatar
coopRC350
yea, I'll not be spending 2k on that. I'll dig through the other threads and figure it out. I want the mechanics to go over it and find what's wrong and I'll make the decision on the work performed. Thanks again.
Old Jul 12, 2018 | 04:53 PM
chiph9's Avatar
chiph9
Water pump could certainly be at fault. And/or thermostat. Both can cause overheating when stopped.
What about the belt-driven fan? It uses a viscous fluid clutch, and if that fluid all leaked out it won't engage.
To test this, wait until the engine is cool to the touch and see how much resistance there is to spinning the fan by hand. It should be firm and not spin freely.
Chip H.
Old Jul 13, 2018 | 06:47 AM
coopRC350's Avatar
coopRC350
Thanks Chip, i'll post an update after I find out what the dealer finds out. See who is the best forum diagnostic tool haha.
Old Jul 13, 2018 | 03:24 PM
coopRC350's Avatar
coopRC350
So the dealer just called me and said the water pump/timing belt is the issue. Also the valve cover gaskets are bad. Hasn’t gotten back to me with a full work up on price but I don’t think that will be too bad.
Old Jul 13, 2018 | 03:55 PM
coopRC350's Avatar
coopRC350
So all of you guys win lol. I need the truck soon so I will likely get them to do it at the dealer. I imagine this is going to be 8-1k which is disappointing since I just bought this thing. Such is life though. Hopefully it doesn’t hurt too much. Thanks for the inputs guys.
Old Jul 13, 2018 | 05:35 PM
EddieK05's Avatar
EddieK05
At least you caught it now rather than something more serious happening down the road. And you'll have the peace of mind knowing that it was actually done now.
Old Jul 14, 2018 | 04:13 AM
coopRC350's Avatar
coopRC350
So the dealer is sourcing parts from a Lexus dealer. Aren’t the engines from the 4Runner tundra and a few others from 2004 the same? If I’m missing something let me know but I’m sure getting them from Toyota would be less expensive. Thoughts?
Old Jul 17, 2018 | 03:17 PM
coopRC350's Avatar
coopRC350
Ok, so I got the car back today. Runs much better and nice to have the a/c back again. Had the complete timing belt package done for 1160$ with my military discount. Other issues found include the cv boots and leaking valve cover. Which I’m going to attempt the tighten down method first and the cv boots didn’t look like too bad of a diy. Thanks again for all the input.
Louay1978
NX - 1st Gen (2015-2021)
15
Mar 26, 2025 06:33 PM
IS25000
Apr 22, 2022 07:30 AM
Bawlzdeep
Mar 6, 2013 09:01 PM
Turbinator
GX - 1st Gen (2003-2009)
Sep 8, 2009 07:16 AM
jishan
RX - 1st Gen (1999-2003)
Aug 2, 2008 06:37 AM
